Alligator-Manager in "V2 0.80" SD ISO for Raspberry
Hi, i use repetier server with an alligator board, there is a linux program that allows me to control the board to make erase, initialization etc.
I wanted to ask where I can find the start file Repetier-Server in the new iso, which in old versions was in /etc/init.d/RepetierServer to perform Repetier as SUPERUSER. Otherwise alligator-manager does not send @execute commands it receives from the command console
Thank you very much
full image
also enable the UART for alligator RPI link
thank you
https://github.com/3Dartists/alligator-manager
following the instructions does not work
Error getting blank page
not be an expert in linux programming
Alligator-manager is used to control the board, not just for loading the firmware to do the firmware upgrade using your GUI but first you have to give the erase command. What I can not do is put in extcommands.xml file commands @execute erase / reset @execute that launch as "sudo alligator-manager --erase" / --reset
sorry
I thought it was very easy to get to from Roland
thanks
repetierserver ALL=NOPASSWD: /sbin/shutdown
repetierserver ALL=NOPASSWD: /usr/local/Repetier-Setup/bin/manageWifiAccess
repetierserver ALL=NOPASSWD: /usr/local/Repetier-Setup/bin/installWebcam
