Nozzle hitting AND lifting off of bed after G33 - Delta
I'm using a He3D K200 Delta with Repetier 0.92.9 FW, and the most recent Repetier Host.
I'm following along with this video exactly:
I'm making sure that my probe height is correct (1.5mm), and that after G32 S2, the distance between nozzle and bed at X0 Y0 Z0 is about 0.1mm (thickness of a piece of paper).
I've done all the steps of the video about 20 times now, and the nozzle is still consistently hitting the bed in some places, and lifting off of it in others.
The bed height map shows deviation of only 0.1mm after Z correction, but when manually measuring my heights I have areas that are 0.5mm off the bed, and areas where Z2.7 is hitting the bed. That's a big variance, and makes it absolutely impossible to print.
What am I doing wrong? I've been working on this every night for three weeks, and I can't find an answer or any tutorial that works.
Here are my 2 most recent height maps:
Bed Height Map
X: -50.00 -33.33 -16.67 0.00 16.67 33.33 50.00
y: 50.00 4.03 4.48 5.06 5.79 6.65 7.60 8.64
y: 33.33 4.50 4.80 5.21 5.80 6.54 7.39 8.35
y: 16.67 4.88 4.99 5.24 5.68 6.28 7.00 7.86
y: 0.00 5.10 5.01 5.10 5.38 5.80 6.43 7.18
y: -16.67 5.15 4.86 4.76 4.88 5.18 5.68 6.33
y: -33.33 5.01 4.55 4.28 4.21 4.36 4.71 5.25
y: -50.00 4.76 4.09 3.63 3.38 3.39 3.61 4.03
after g33
y: 50.00 6.99 6.99 7.01 7.05 7.04 7.01 7.04
y: 33.33 7.00 7.00 7.00 7.05 7.04 7.03 7.06
y: 16.67 6.99 7.00 7.01 7.05 7.03 7.03 7.04
y: 0.00 6.95 6.98 6.98 7.01 6.98 6.98 7.00
y: -16.67 6.99 6.98 7.01 7.04 7.00 7.03 7.04
y: -33.33 7.01 6.99 7.00 7.05 7.01 7.03 7.00
y: -50.00 7.00 6.98 6.99 7.00 7.00 7.00 6.99
Please note that no matter how I have the bed physically set, Z-probing ALWAYS shows the back-right side of the bed (around X66 Y38) as way too low, but when watching the hotend move it is clearly the hotend assembly moving up away from the bed, not that the bed is actually physically lower. I have tried to compensate for this by physically raising that side of the bed, and it doesn't really change anything when it comes to Z-probing.
