Commands waiting?
Hello, new user and new to forum. I have been trying to use repetier on my new printer rapide lite 200 which is using the rumba/taurino driver compatible with ATmega2560 on Com3. I was using repetier succesfully to run calibration tests and then I lost the ability to print from repetier. Prints would freeze or connections were lost. I then was using repetier to move the extruder around to calibrate and had axes control without issues.
Currently I cannot do anything with repetier. My computer recognizes the printer on com3 and I can connect to it with repetier but that is it. When I connect it tells me I have 5 commands waiting and the printer is unresponsive. If I do anything the commands add up. If I click the OK button , the commands go away til I get to idle and then suddenly there is another command waiting? I can print from SD card on the printer but really want to have control with my computer again. I have changed usb cables, baud rates and anything else I can think of but without success.
I am not sure if it is my printer or not but would appreciate any guidance or assistance.
What ended up solving it was changing the COM port to COM1 in the Port-Settings tab (in device manager properties) and restarting my computer. It may not be related, but it's cleared up COM port issues with my printer before...even if it wasn't with repetier haha.
Hello
I'm having trouble with this "waiting command", the serial port is ok, the baudrate as well. Using an Arduino Mega and ramps 1.4. The firmware version is 0.92
What might be happening??
thank you
Hi
What fixed the problem for me was to Disable the "Reset on Connect".
Thanks.
just changed the port and then restarted the computer and it worked...
just restarting does not work...
moi aussi j ai le même problème
apparemment je suis connecter a l imprimante
dans configuration jje n est pas axe a configuration eeprom
et dans contrôle manuel je ne peux pas déplacer quoi que ce soi
si vous pouver me depanner merci
Je ne sais pas ce qu il ses passer avec mon précédant message ,je vais le traduire
mon problème est que quand je me connecte a mon imprimante l'icone passe au vert
Je ne peux pas intervenir dans la configuration de l' eeprom
Je ne peux pas non plus utilisée la commande manuel
j ai fait ces esse sur deux carte différente cela ne change rien
le port com (5) est le bon il ma servi a flaché ma carte MKS GEN L 1. 0
j'ai aussi essayer toute les vitesse rien ne change
si vous pouvez me dépanner MERCI
