Unable to access eeprom configuration....
LeoLeo
edited October 2016 in Bug Reports
I have an Anet A8 3D Printer and I'm using Repetier-Host V1.6.2.
Code M115 returns:
FIRMWARE_NAME:ANET_A8_20160525  http://www.anet3d.com/ VERSION:ANET V1.0 MACHINE_TYPE:ANET_A8 EXTRUDER_COUNT:1
I am unable to access "Firmware EEPROM configuration" within the host.
Any help is appreciated.
Thank you.
Leo
  • Different firmwares have different eeprom settings. We only support Marlin and Repetier, but firmware does not report any of them. Maybe just renamed but host does not know.
  • Understood.
    I will try to contact Anet to see what can be done.
    Thank you.
    Leo
  • If it is marlin and you have the sources (you should have as it is gpl licensed) you could rename the output containing Marlin in firmware name as well.
