Manual Heat Bed...
I just finished wiring my setup up. I verified my heatbed working without connecting my ramps. It's a mains aluminum heat bed. So I have an SSR for the mains and the other is the +/- for the bed from the controller. My question is that when I manually turn on the heat bed it powers on (verified with the LED from the SSR) but then powers off 5 seconds after. Thermistor shows the temp rise... then stops because it shut itself off. Any help as to why it shuts itself off would be greately appreciated.
