Bare Minimum Server Logs
Is there a way to only log basic print info such as:
Print xyz started at 1300
Print xyz finished at 1335 filament used 2.1m
Essentially the info that's sent in a Print Message. The problem I'm having is the server crashes due to the AutoPrint bug and all the print messages get deleted when the server restarts. If there is a way to retrieve the print messages after the server restarts then that would suffice.
Thanks repetier that would be awesome. I believe you already said the AutoPrint bug would be fixed next release. Here's the previous post.
https://forum.repetier.com/discussion/2136/autostart-next-job-crashes-if-no-jobs-in-que#latest
