Bare Minimum Server Logs
Is there a way to only log basic print info such as:
Print xyz started at 1300
Print xyz finished at 1335 filament used 2.1m
Essentially the info that's sent in a Print Message. The problem I'm having is the server crashes due to the AutoPrint bug and all the print messages get deleted when the server restarts. If there is a way to retrieve the print messages after the server restarts then that would suffice.
