Add security micro
I have e homemade printer, and i'd like add a micro on the door of te printer. Someone habe an idea where i can insert an if on the firmware??
Thx
LB
  • Ok, have just added a door open detection in dev version. See config tool for endstop pin configuration, there is now also a door open pin. It will prevent new commands from serial/sd so essentially stops the print and will continue when you close the door. Not that you should do it as the pause might cause a blob where you stop but it will prevent moves after a short while.
  • I find a open door pin on configuration on your site?? I've search but i don't find where is this option.
  • In our config tool you need of course dev version as i just added it. It is below the xyz endstop configuration. Or if you prefer github use dev tree and check configuration.h.
