COREXY PRINTER ENDSTOP/HOMING INVERTED
Repetier Firmware
MKS GENS 1.4 Board
CORE XY
I recently made a COREXY printer everything has been smooth sailing for me until I got to the endstops I've been stuck on the endstops for about 5 days now just when i think I had everything correct I change one or two lines and they all start going the wrong way and homing the wrong way. I'm using mechanical endstops ( 2 wire blk/red one on each end) and have them plugged into the min slots on my MKS 1.4. At the moment the X axis is homing in the correct direction (to the right)but the movement is mirrored If I move left it goes right and vise versa the Y axis however is moving correctly but it wont home at all when I hit home Y it just moves a little bit and stops the Z axis is only working in one direction which is also inverted If I move down it goes up. My other question is since I have a core xy setup my Z axis seperate would have to move all the way up to the top to home how would I set up printing so it comes back down as the layers increase do I invert this? any help or direction would be appreciated if anyone has the same board or same setup I wouldn't mind taking a glace at your firmware and see how to do things correctly.
what I'm trying to accomplish
X axis end stop home to the right of printer
Y axis end stop home to the back of printer (move forward)
Z axis end stop home to the top of the printer
my config.h
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 120
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
x
  • x and y sounds like max homing so direction would be 1 and M119 should show xy max endstops.
    z is min I think but that depends if your bed or extruder is homing.
    First make movements go correct way, then check M119 shows x max, y max and z min.
    Make also sure Endstop distance after homing is set so it would untrigger the endstop. If not this can do unwanted things with core xy.
  • thanks for the reply I have changed the homing as suggested my issue with the correcting the movement is maybe I'm changing the wrong settings to invert the direction do I use the
    or
    sorry for the newb question I've only flashed firmware once before
  • endstop inverting toggles when endstops signal a trigger. Check M119 for current state. It must be low untriggered and high triggered. Here you also see if the right endstops are configured. min = 0 pos, max = trigger at max pos. From your descrtiption xy would be max, z min.
    invert xyz dir invert motor direction. For z it's simple. xy with corexy change how it behaves. With the computations and mapping it is quite confusing so I'd just go over xy invert and drive system variation until xy moves as you need it. If you have simple motor connector you can also rotate connector 180° insead of toggling invert dir, that has the same effect.
