slic3r os x
Hello all,
i'l new in 3d printer and i work on mac 10.6.8 when install repetier 0.56 it's ok but in repetier there is a slic3r and in may librayry/support application/slice3r i have a a 3 file filament, print and printer and slic3r.ini but this 3 files is empty and in repetier i don't have access to the roll panel print setting printer setting and filament beacause is empty .
When i slice is ok but when i run g-code he tell me print stopped du errors fix the error and use M999 to restart ( temperature is reset, Set it after restarting). How can i fix the problem with the folder for slic3r
If you have an idea it's great
Thank's a lot in advance to read me and good eveninf for everything
Another problem and i don't no how can i fix this too
When i run my print after a few seconds have this message in toggle log < 09:49:09: echo: cold extrusion prevented
N3273 G1 X101.40 Y87.15 E6.4586 *113
N3274 M105 *53
N3275 G1 X101.94 Y87.21 E6.4880 *114
N3276 G1 X104.20 Y84.96 E6.6591 *123
Error:0
: Extruder switched off. MINTEMP triggered !
Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
N3277 M105 *54
N3278 G1 X104.36 Y85.41 E6.6847 *127
if you have an idea for a beginner thanks a lot yet
thank you again and good day for you
