jerk and stepper motor stalling
So I have a custom built 3d printer. I'm having some problems with my y axis. It's a leadscrew with a hefty nema23 motor. It should in my opinion be strong enough to drive this axis. But it stalls no matter what I do. The mechanics are fine, it glides fine when I try too move it manually. But when I try to print something it stalls like crazy.
The controller is set to 1/8 microstepping, with a udoo quad and radds 1.5 controlling it.
When I try high jerk setting, above 10 I get stalling. And the same with under 8 jerk.
I'm just wondering if there is a combination of acceleration, top speed, and jerk that is causing this.
I have it running pretty slow at the moment.
With both Y axis acceleration set too 100, jerk at 10. And max speed is 40mm/s. With infill set too 30mm/s. But still it's hopeless ☺️
I'm rebuilding the axis with belt and pulley. But I would love to figure this issue out as it is driving med mad
I'm guessing that's quite high thread mass
The steps per mm is 320, so that can't be the problem, my x axis is much much heavier, but with a 20mm per rotation leadscrew. That works perfectly.
