top layer problem using nozzle diameter of 1.0mm
dear all,
I'm using a nozzle of 1.0mm diameter with slic3r and repetier host 1.0.6. After slice with slic3r the top layer(s) are not lined at all. I've tried a lot of parameters in slic3r, top layer, perimerters, infill etc. without success. Can pls sb help? Did this happen to sb else? Thanks in advance for any help ;-)
Jordi
