Help my maddness
Help,
I
dont know if this is in the correct area but,
I
have just finished building a new bigger printer, I have a radds 1.5
control and have set it up in as far as i can remember exactly the
same way as i set the last one up, except I have used Raps128 stepper
drivers.
I
made a new software install with the new dimensions ect with the
Repetier-Firmware
0.92.x with Configuration Tool
When
I power the board up all seems fine the steppers hold the LEDs on the
stops work as expected, I connect with Repetier server pro and I have
no control tab. In the top left of the screen is normally a green set
of links but these are replaced with a set of yellow what look like
signal bars from a phone.
If
I disconnect I get the normal brown broken link.
If
I go to the printer set-up screen it will down load the information
from the firmware.
Please
help I am at the point of hitting the thing with a cricket bat.
I
expect it is some stupid operator issue but I am to annoyed to be
able to see it.
in advance
Martin.
