IHost has a property Connection which has a Property Analyser. That is the analyser that gets updated while printing. So all these variables show the current state of the printer. From there it should be pretty easy to get everything you want. If you are only interested in position changes add a callback to OnPosChange event.
Repetier, OK, thanks for the Analyzer informations, very helpful, this part of my plugin is now functional.
Now, is it possible to replicate the Visualization group box of the Preview tab (the one with First Layer / Last Layer)? If yes, which properties/events or controls should I use?
No, that is not possible. It is hardcoded inside the editor. And rewriting it is also not easy or impossible. I have added the following to IGcodeEditor so you can at least use the editor commands whcih are already there. They will be included in Version 1.1
/// <summary>
/// Visualization mode for gcode.
/// 0 = Show all layer, 1 = show one layer, 2 = show layer range
Not clear. We want to include a new connector for repetier-server, then we call it 1.1 and publish it. And that is what we are working on. So till mid february I hope.
public event OnPosChange eventPosChanged;
is the event you might want to book.
Why do you need gcodes that got send? Normally the analyser gives you anything you need.
"...The analyser gets called for each gcode and moves..."
While printing?
I'm a little slow to understand, do you think you can build a simple plugin (source code) to demonstrate the basic use of your analyser?
I'm sure it'll explain everything faster.
Thank you!
Christian
Christian
/// <summary>
/// </summary>
int ShowMode { get; set; }
int ShowMinLayer {get; set;}
int ShowMaxLayer { get; set; }
int MaxLayer { get; }
Do you have an ETA for version 1.1?
