Setting the WRONG temps in G-Code
I thought I screwed something up, I am NOT sure what is going on as I have compltetely uninstalled, wiped out, and re-installed Repetier Host on my computer again... And this is was continues..
I have my ABS temps set for a 110c bed, and 230c extruder. All is good, but when I slice an object the g-code write and M190 to S50, M104 to S200 and M109 to S200. So my temps end up wrong. I try to print... and yep.. wrong temps are set. I try to print using OctoPrint... same shit.
If I edit the g-code to be M190 S110, M104 to S230, and M109 to S230..... ALL WORKS.
Has Anyone else had this issue?? And if so.. how did you fix it?
thank you,
