Booting into Touchscreen Mode on Raspberry Pi 3 + 7inch Touchscreen
Hello.
I managed to install repetier server on my raspberry pi 3 and run it via SSH by sudo service lightdm stop and executing sudo xinit ./rs -- -nocursor. Now i would like it to boot into touchscreen mode automatically but i think the guide on how to do that (LINK) is obsolete since i don't have the /etc/inittab and /etc/rc.local.
I'm not very familiar with linux and would appreciate if someone can help me out.
Follow the instructions in https://www.repetier-server.com/booting-into-touchscreen-mode-for-linux/
to add openbox and kweb.
Make the scripts rs and startserver.sh in /home/pi/ and mark them executable
(sudo chmod +x startserver.sh & sudo chmod +x rs).
In /etc/rc.local add the following lines at the end of script (just before exit 0):
/usr/bin/xinit /home/pi/rs -- -nocursor
/home/pi/startserver.sh
Regards
repman
You can have full .iso file of your RPI p3 ??
I fail with the whole package installation
waiting time ??
I downloaded the SPARKLAB version found on the German forum RepRap
I also have the full version of the Server
Ho un LCD Waveshare 5 " RPI 3
thanks
I want to start with new configuration from the beginning
I do not know which file to load for raspberry P3
armhf: libc 2.16 like used in Debian Jessie. Use armel if you have a older libc.
or
amd64: libc 2.13 like used in Debian Wheezy
ok works
loading with armhf
just that I have finished the activation key for 5 times-
sorry I only did tests with raspberry PI
where you are connected to the code with annulate evidence of raspberry
I do not understand
great man
image file. I am considering buying multiple
licences and it would be really convenient to shorten the installation
process.
