Where to find configuration file
Hello,
I want to connect my printer with the repetier server. I have to upload the configuration file to the server, but I don't know where to find the configuration file (and which file type it is). Does someone know where I can find the configuration file?
"No understandable response on this port. Please check baud rate and firmware".
I'm sure it is not the baud rate; I've selected the right one, and after this message, I selected "autodetect", but that didn't help. I think it is the firmware, but how do you check/update it? When I select "install firmware" on this site, I have to fill in the whole configuration of the printer. I know a few things about the printer, but not that much as questioned.
In your comment you also said I have to check the created configuration, but I can't find that either?
And at last I was wondering: how do I check if I have the right firmware, or how do I update it?
If I want to connect with "serial connection", localhost says it is connected, but there is "1 Commands waiting". After a while I get the message: "Communication timeout - reset send buffer block", and it starts again.
