G1 Z 0.400 F7800.000
Hi, and thanks in advance for you suggestions.
On or about line 22 on the G-Code for any print, I get this entry after slicing. Obviously this value is too high for the filament to adhere to the print bed. it does not matter what size nozzle I use. I can see an air gap between the nozzle and the bed. So changing the g-code to
"G1 Z 0.040 F7800.000" this places a nice brim and skirt on my printing object. Where in the world and what numbers do I use to get it to the value I choose, as opposed to manually changing every g-code? How do I make the default change to this number? I bet it is as simple as someone identifying where the value is changed and explaining the math involved.
Sincerely,
Israel
