Server commands reset and delays
Hello,
Im running RS on Pi3 when i set the bed or extruder temperature by typing in a number it resets to zero after 60 seconds?
If i stop a print it takes a long time for the machine to stop even tho the values have changed back to zero?
Cheer
  • Does is happen when idle or does it happen while printing? While printing the command gets executed delayed so there might be delay.
    What firmware are you using?
  • Resets to zero when idle after 60 seconds.
    Yes delay while printing after stop command.
    Im using Repetier V092
  • I plugged in a pixel screen and found def error on my extruder happens around 120 degrees Ill have to check my temp settings in the firmware. RS needs to show def errors.
    or else it just sits there locked up and waiting while the temp drops
  • The log shows the error message from printer if you had it activated.
    Showing such errors directly would be great, but there is no defined output on error. Would be a good idea to add such a signal to firmware.
  • Still happening just hangs and sets temps to zero during print
    Any idea why?
    > 13:18:39.917: wait
    < 13:18:40.035: N76017 M105
    < 13:18:40.035: N76018 G90
    > 13:18:40.042: ok 10481
    < 13:18:40.042: N76019 M82
    > 13:18:40.042: T:102.26 /0 B:28.49 /0 B@:0 @:0 T0:102.26 /0 @0:0 T1:27.68 /0 @1:0
    < 13:18:40.042: N76020 M106 S0
    > 13:18:40.044: ok 10482
    < 13:18:40.045: N76021 M140 S40
    > 13:18:40.048: ok 10483
    < 13:18:40.049: N76022 M190 S40
    > 13:18:40.049: ok 10484
    < 13:18:40.049: N76023 M104 S200 T0
    > 13:18:40.049: ok 10485
    < 13:18:40.049: N76024 M109 S200 T0
    > 13:18:40.050: TargetBed:40
    < 13:18:40.050: N76025 G28 ; home all axes
    > 13:18:40.052: ok 10486
    < 13:18:40.053: N76026 G92 E0
    < 13:18:40.146: N76027 G1 E-3.0000 F1000
    > 13:18:41.068: T:101.85 /0 B:28.49 /40 B@:255 @:0 T0:101.85 /0 @0:0 T1:27.68 /0 @1:0
    > 13:18:42.069: T:101.43 /0 B:28.60 /40 B@:255 @:0 T0:101.43 /0 @0:0 T1:27.68 /0 @1:0
    > 13:18:43.072: T:101.02 /0 B:28.84 /40 B@:255 @:0 T0:101.02 /0 @0:0 T1:27.68 /0 @1:0
    > 13:18:44.071: T:100.61 /0 B:29.30 /40 B@:255 @:0 T0:100.61 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:45.070: T:100.16 /0 B:29.77 /40 B@:255 @:0 T0:100.16 /0 @0:0 T1:27.68 /0 @1:0
    > 13:18:46.074: T:99.78 /0 B:30.09 /40 B@:255 @:0 T0:99.78 /0 @0:0 T1:27.68 /0 @1:0
    > 13:18:47.074: T:99.38 /0 B:30.46 /40 B@:255 @:0 T0:99.38 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:48.078: T:98.98 /0 B:30.92 /40 B@:255 @:0 T0:98.98 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:49.077: T:98.58 /0 B:31.28 /40 B@:255 @:0 T0:98.58 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:50.076: T:98.17 /0 B:31.74 /40 B@:255 @:0 T0:98.17 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:51.079: T:97.77 /0 B:32.20 /40 B@:255 @:0 T0:97.77 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:52.084: T:97.37 /0 B:32.57 /40 B@:255 @:0 T0:97.37 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:53.083: T:97.03 /0 B:33.03 /40 B@:255 @:0 T0:97.03 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:54.082: T:96.63 /0 B:33.49 /40 B@:255 @:0 T0:96.63 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:55.087: T:96.22 /0 B:33.94 /40 B@:255 @:0 T0:96.22 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:56.085: T:95.85 /0 B:34.40 /40 B@:255 @:0 T0:95.85 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:57.088: T:95.48 /0 B:34.77 /40 B@:255 @:0 T0:95.48 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:58.088: T:95.11 /0 B:35.23 /40 B@:255 @:0 T0:95.11 /0 @0:0 T1:27.56 /0 @1:0
    > 13:18:59.088: T:94.74 /0 B:35.78 /40 B@:255 @:0 T0:94.74 /0 @0:0 T1:27.56 /0 @1:0
    > 13:19:00.091: T:94.40 /0 B:36.24 /40 B@:255 @:0 T0:94.40 /0 @0:0 T1:27.56 /0 @1:0
    > 13:19:01.090: T:93.99 /0 B:36.61 /40 B@:255 @:0 T0:93.99 /0 @0:0 T1:27.56 /0 @1:0
    > 13:19:02.090: T:93.62 /0 B:37.06 /40 B@:255 @:0 T0:93.62 /0 @0:0 T1:27.56 /0 @1:0
    > 13:19:03.093: T:93.25 /0 B:37.52 /40 B@:255 @:0 T0:93.25 /0 @0:0 T1:27.44 /0 @1:0
    > 13:19:04.093: T:92.88 /0 B:37.98 /40 B@:255 @:0 T0:92.88 /0 @0:0 T1:27.56 /0 @1:0
    > 13:19:05.096: T:92.51 /0 B:38.44 /40 B@:255 @:0 T0:92.51 /0 @0:0 T1:27.44 /0 @1:0
    > 13:19:06.096: T:92.14 /0 B:38.90 /40 B@:255 @:0 T0:92.14 /0 @0:0 T1:27.44 /0 @1:0
    > 13:19:07.095: T:91.83 /0 B:39.36 /40 B@:255 @:0 T0:91.83 /0 @0:0 T1:27.44 /0 @1:0
    > 13:19:07.518: ok 10487
    > 13:19:07.518: TargetExtr0:200
    > 13:19:07.518: ok 10488
    < 13:19:07.518: N76028 M117 ETA 15:12:19 day 20
    > 13:19:08.530: T:91.30 /200 B:39.91 /40 B@:255 @:255 T0:91.30 /200 @0:255 T1:27.44 /0 @1:0
    > 13:19:09.533: T:91.21 /200 B:40.24 /40 B@:0 @:255 T0:91.21 /200 @0:255 T1:27.44 /0 @1:0
    > 13:19:10.532: T:91.58 /200 B:40.48 /40 B@:0 @:255 T0:91.58 /200 @0:255 T1:27.44 /0 @1:0
    > 13:19:11.531: T:92.29 /200 B:40.54 /40 B@:0 @:255 T0:92.29 /200 @0:255 T1:27.44 /0 @1:0
    > 13:19:12.535: T:93.28 /200 B:40.54 /40 B@:0 @:255 T0:93.28 /200 @0:255 T1:27.44 /0 @1:0
    > 13:19:13.535: T:94.49 /200 B:40.54 /40 B@:0 @:255 T0:94.49 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:14.538: T:95.85 /200 B:40.48 /40 B@:0 @:255 T0:95.85 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:15.538: T:97.15 /200 B:40.42 /40 B@:0 @:255 T0:97.15 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:16.537: T:98.67 /200 B:40.36 /40 B@:0 @:255 T0:98.67 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:17.540: T:100.22 /200 B:40.24 /40 B@:0 @:255 T0:100.22 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:18.541: T:101.85 /200 B:40.18 /40 B@:0 @:255 T0:101.85 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:19.543: T:103.47 /200 B:40.06 /40 B@:0 @:255 T0:103.47 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:20.543: T:105.13 /200 B:39.91 /40 B@:255 @:255 T0:105.13 /200 @0:255 T1:27.32 /0 @1:0
    > 13:19:21.544: T:106.62 /200 B:39.82 /40 B@:255 @:255 T0:106.62 /200 @0:255 T1:27.32 /0 @1:0
  • Just stops heating?
    > 12:01:49.107: wait
    < 12:01:49.817: N52 M105
    > 12:01:49.828: ok 52
    < 12:01:49.828: N53 M84
    < 12:01:49.829: N54 M140 S30
    > 12:01:49.829: T:37.69 /0 B:21.10 /0 B@:0 @:0 T0:37.69 /0 @0:0 T1:20.98 /0 @1:0
    < 12:01:49.829: N55 M190 S30
    > 12:01:49.833: ok 53
    < 12:01:49.833: N56 M117 Preheating Bed
    > 12:01:49.833: ok 54
    < 12:01:49.833: N57 M120 S50 P1
    > 12:01:49.834: TargetBed:30
    < 12:01:49.834: N58 M117 Printer Moving
    > 12:01:49.834: ok 55
    < 12:01:49.834: N59 M120 S0 P1
    < 12:01:49.939: N60 M117 Printer Moving
    < 12:01:50.049: N61 M120 S50 P1
    > 12:01:50.849: T:37.61 /0 B:21.10 /30 B@:127 @:0 T0:37.61 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:51.848: T:37.61 /0 B:21.10 /30 B@:127 @:0 T0:37.61 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:52.851: T:37.52 /0 B:21.22 /30 B@:127 @:0 T0:37.52 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:53.852: T:37.44 /0 B:21.34 /30 B@:127 @:0 T0:37.44 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:54.851: T:37.35 /0 B:21.46 /30 B@:127 @:0 T0:37.35 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:55.854: T:37.26 /0 B:21.59 /30 B@:127 @:0 T0:37.26 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:56.853: T:37.18 /0 B:21.71 /30 B@:127 @:0 T0:37.18 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:57.856: T:37.09 /0 B:21.95 /30 B@:127 @:0 T0:37.09 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:58.857: T:37.01 /0 B:22.07 /30 B@:127 @:0 T0:37.01 /0 @0:0 T1:20.98 /0 @1:0
    > 12:01:59.857: T:36.92 /0 B:22.32 /30 B@:127 @:0 T0:36.92 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:00.859: T:36.84 /0 B:22.44 /30 B@:127 @:0 T0:36.84 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:01.859: T:36.75 /0 B:22.56 /30 B@:127 @:0 T0:36.75 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:02.862: T:36.67 /0 B:22.80 /30 B@:127 @:0 T0:36.67 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:03.863: T:36.58 /0 B:23.05 /30 B@:127 @:0 T0:36.58 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:04.864: T:36.50 /0 B:23.17 /30 B@:127 @:0 T0:36.50 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:05.865: T:36.41 /0 B:23.41 /30 B@:127 @:0 T0:36.41 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:06.864: T:36.32 /0 B:23.54 /30 B@:127 @:0 T0:36.32 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:07.867: T:36.32 /0 B:23.78 /30 B@:127 @:0 T0:36.32 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:08.867: T:36.24 /0 B:24.02 /30 B@:127 @:0 T0:36.24 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:09.868: T:36.15 /0 B:24.15 /30 B@:127 @:0 T0:36.15 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:10.870: T:36.07 /0 B:24.39 /30 B@:127 @:0 T0:36.07 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:11.870: T:35.98 /0 B:24.51 /30 B@:127 @:0 T0:35.98 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:12.869: T:35.90 /0 B:24.76 /30 B@:127 @:0 T0:35.90 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:13.873: T:35.81 /0 B:24.88 /30 B@:127 @:0 T0:35.81 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:14.873: T:35.81 /0 B:25.12 /30 B@:127 @:0 T0:35.81 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:15.876: T:35.73 /0 B:25.37 /30 B@:127 @:0 T0:35.73 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:16.876: T:35.64 /0 B:25.49 /30 B@:127 @:0 T0:35.64 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:17.874: T:35.56 /0 B:25.73 /30 B@:127 @:0 T0:35.56 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:18.879: T:35.47 /0 B:25.85 /30 B@:127 @:0 T0:35.47 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:19.878: T:35.38 /0 B:26.10 /30 B@:127 @:0 T0:35.38 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:20.881: T:35.38 /0 B:26.22 /30 B@:127 @:0 T0:35.38 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:21.881: T:35.30 /0 B:26.46 /30 B@:127 @:0 T0:35.30 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:22.880: T:35.21 /0 B:26.59 /30 B@:127 @:0 T0:35.21 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:23.885: T:35.13 /0 B:26.83 /30 B@:127 @:0 T0:35.13 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:24.884: T:35.04 /0 B:26.95 /30 B@:127 @:0 T0:35.04 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:25.883: T:35.04 /0 B:27.20 /30 B@:127 @:0 T0:35.04 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:26.886: T:34.96 /0 B:27.32 /30 B@:127 @:0 T0:34.96 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:27.886: T:34.87 /0 B:27.44 /30 B@:127 @:0 T0:34.87 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:28.890: T:34.87 /0 B:27.68 /30 B@:127 @:0 T0:34.87 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:29.889: T:34.70 /0 B:27.80 /30 B@:127 @:0 T0:34.70 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:30.888: T:34.70 /0 B:28.05 /30 B@:127 @:0 T0:34.70 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:31.891: T:34.62 /0 B:28.17 /30 B@:127 @:0 T0:34.62 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:32.892: T:34.53 /0 B:28.41 /30 B@:127 @:0 T0:34.53 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:33.895: T:34.53 /0 B:28.54 /30 B@:127 @:0 T0:34.53 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:34.894: T:34.44 /0 B:28.66 /30 B@:127 @:0 T0:34.44 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:35.894: T:34.36 /0 B:28.90 /30 B@:127 @:0 T0:34.36 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:36.897: T:34.36 /0 B:29.02 /30 B@:127 @:0 T0:34.36 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:37.896: T:34.27 /0 B:29.27 /30 B@:127 @:0 T0:34.27 /0 @0:0 T1:20.85 /0 @1:0
    > 12:02:38.900: T:34.19 /0 B:29.39 /30 B@:127 @:0 T0:34.19 /0 @0:0 T1:20.98 /0 @1:0
    > 12:02:39.391: ok 56
    < 12:02:39.391: N62 M117 ETA 12:10:18 day 7
    > 12:02:39.400: ok 57
    > 12:02:39.501: ok 58
    < 12:02:39.502: N63 M117 Printer Moving
    > 12:02:39.510: ok 59
    < 12:02:39.510: N64 M120 S0 P10
    > 12:02:39.514: ok 60
    < 12:02:39.514: N65 M117 Printer Moving
    > 12:02:39.522: ok 61
    < 12:02:39.522: N66 G28
    < 12:02:39.589: N67 G1 F3000 Z200
    > 12:02:39.625: ok 62
    < 12:02:39.625: N68 T1
    > 12:02:39.636: ok 63
    < 12:02:39.636: N69 M104 S0
    > 12:02:39.645: ok 64
    < 12:02:39.646: N70 T0
    > 12:02:39.646: ok 65
    < 12:02:39.646: N71 M104 S0
    > 12:02:39.657: ok 66
    < 12:02:39.657: N72 T0
    < 12:02:39.700: N73 M104 S245
    < 12:02:39.810: N74 M109 S245
    < 12:02:39.920: N75 M105
    < 12:02:39.925: N76 M117 Preheating Extruder
    > 12:02:45.532: FlowMultiply:100
    > 12:02:45.533: X:0.00 Y:0.00 Z:684.000 E:0.0000
    > 12:02:45.533: ok 67
    < 12:02:45.533: N77 M117 ETE 00:05:51
    > 12:02:45.536: ok 68
    < 12:02:45.537: N78 M105
    > 12:02:55.227: FlowMultiply:100
    > 12:02:55.239: ok 69
    > 12:02:55.309: TargetExtr1:0
    > 12:02:55.310: ok 70
    > 12:02:55.311: FlowMultiply:100
    > 12:02:55.320: ok 71
    < 12:02:55.321: N79 M117 Layer 0/40
    < 12:02:55.340: N80 M105
    > 12:02:55.392: TargetExtr0:0
    > 12:02:55.392: ok 72
    > 12:02:55.393: FlowMultiply:100
    > 12:02:55.393: ok 73
    < 12:02:55.393: N81 M120 S50 P1
    > 12:02:55.394: TargetExtr0:245
    > 12:02:55.394: ok 74
    > 12:02:55.395: TargetExtr0:245
    > 12:02:56.408: T:33.25 /245 B:30.00 /30 B@:0 @:255 T0:33.25 /245 @0:255 T1:20.85 /0 @1:0
    > 12:02:57.407: T:33.42 /245 B:30.00 /30 B@:0 @:255 T0:33.42 /245 @0:255 T1:20.98 /0 @1:0
    > 12:02:58.410: T:33.93 /245 B:30.09 /30 B@:0 @:255 T0:33.93 /245 @0:255 T1:20.98 /0 @1:0
    > 12:02:59.409: T:34.79 /245 B:30.00 /30 B@:0 @:255 T0:34.79 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:00.409: T:35.90 /245 B:30.00 /30 B@:0 @:255 T0:35.90 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:01.412: T:37.26 /245 B:30.00 /30 B@:0 @:255 T0:37.26 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:02.413: T:38.97 /245 B:29.88 /30 B@:127 @:255 T0:38.97 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:03.416: T:40.51 /245 B:29.88 /30 B@:127 @:255 T0:40.51 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:04.415: T:41.90 /245 B:29.88 /30 B@:127 @:255 T0:41.90 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:05.414: T:43.35 /245 B:29.88 /30 B@:127 @:255 T0:43.35 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:06.417: T:45.00 /245 B:30.00 /30 B@:0 @:255 T0:45.00 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:07.417: T:46.71 /245 B:30.09 /30 B@:0 @:255 T0:46.71 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:08.417: T:48.54 /245 B:30.00 /30 B@:0 @:255 T0:48.54 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:09.420: T:50.34 /245 B:30.00 /30 B@:0 @:255 T0:50.34 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:10.419: T:52.02 /245 B:30.00 /30 B@:0 @:255 T0:52.02 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:11.423: T:53.69 /245 B:29.88 /30 B@:127 @:255 T0:53.69 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:12.422: T:55.47 /245 B:29.88 /30 B@:127 @:255 T0:55.47 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:13.422: T:57.54 /245 B:29.88 /30 B@:127 @:255 T0:57.54 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:14.426: T:59.41 /245 B:29.88 /30 B@:127 @:255 T0:59.41 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:15.425: T:61.13 /245 B:29.88 /30 B@:127 @:255 T0:61.13 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:16.428: T:62.78 /245 B:30.00 /30 B@:0 @:255 T0:62.78 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:17.428: T:64.48 /245 B:30.09 /30 B@:0 @:255 T0:64.48 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:18.428: T:66.25 /245 B:30.09 /30 B@:0 @:255 T0:66.25 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:19.431: T:68.06 /245 B:30.09 /30 B@:0 @:255 T0:68.06 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:20.431: T:69.92 /245 B:30.00 /30 B@:0 @:255 T0:69.92 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:22.007: T:71.61 /245 B:29.88 /30 B@:127 @:255 T0:71.61 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:23.007: T:73.32 /245 B:29.88 /30 B@:127 @:255 T0:73.32 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:24.007: T:75.00 /245 B:29.88 /30 B@:127 @:255 T0:75.00 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:25.011: T:76.71 /245 B:29.88 /30 B@:127 @:255 T0:76.71 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:26.012: T:78.67 /245 B:29.88 /30 B@:127 @:255 T0:78.67 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:27.012: T:80.38 /245 B:30.00 /30 B@:0 @:255 T0:80.38 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:28.015: T:82.02 /245 B:30.00 /30 B@:0 @:255 T0:82.02 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:29.015: T:83.65 /245 B:30.09 /30 B@:0 @:255 T0:83.65 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:30.019: T:85.32 /245 B:30.09 /30 B@:0 @:255 T0:85.32 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:31.020: T:86.99 /245 B:30.00 /30 B@:0 @:255 T0:86.99 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:32.019: T:88.65 /245 B:30.00 /30 B@:0 @:255 T0:88.65 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:33.023: T:90.34 /245 B:29.88 /30 B@:127 @:255 T0:90.34 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:34.023: T:92.01 /245 B:29.76 /30 B@:127 @:255 T0:92.01 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:35.027: T:93.62 /245 B:29.76 /30 B@:127 @:255 T0:93.62 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:36.027: T:95.23 /245 B:29.88 /30 B@:127 @:255 T0:95.23 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:37.028: T:96.97 /245 B:29.88 /30 B@:127 @:255 T0:96.97 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:38.031: T:98.51 /245 B:30.00 /30 B@:0 @:255 T0:98.51 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:39.032: T:100.06 /245 B:30.09 /30 B@:0 @:255 T0:100.06 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:40.035: T:101.69 /245 B:30.09 /30 B@:0 @:255 T0:101.69 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:41.035: T:103.25 /245 B:30.00 /30 B@:0 @:255 T0:103.25 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:42.035: T:104.84 /245 B:30.00 /30 B@:0 @:255 T0:104.84 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:43.038: T:106.37 /245 B:30.00 /30 B@:0 @:255 T0:106.37 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:44.040: T:107.90 /245 B:29.88 /30 B@:127 @:255 T0:107.90 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:45.040: T:109.46 /245 B:29.76 /30 B@:127 @:255 T0:109.46 /245 @0:255 T1:20.85 /0 @1:0
    > 12:03:46.043: T:110.99 /245 B:29.76 /30 B@:127 @:255 T0:110.99 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:47.044: T:112.52 /245 B:29.88 /30 B@:127 @:255 T0:112.52 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:48.046: T:114.18 /245 B:29.88 /30 B@:127 @:255 T0:114.18 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:49.048: T:115.68 /245 B:30.00 /30 B@:0 @:255 T0:115.68 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:50.048: T:117.07 /245 B:30.00 /30 B@:0 @:255 T0:117.07 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:51.051: T:118.50 /245 B:30.09 /30 B@:0 @:255 T0:118.50 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:52.051: T:119.90 /245 B:30.00 /30 B@:0 @:255 T0:119.90 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:53.055: T:121.40 /245 B:30.00 /30 B@:0 @:255 T0:121.40 /245 @0:255 T1:20.98 /0 @1:0
    > 12:03:54.055: T:122.95 /245 B:30.00 /30 B@:0 @:0 T0:122.95 /245 @0:0 T1:20.98 /0 @1:0
    > 12:03:55.056: T:124.20 /245 B:29.88 /30 B@:0 @:0 T0:124.20 /245 @0:0 T1:20.98 /0 @1:0
    > 12:03:56.059: T:125.11 /245 B:29.88 /30 B@:0 @:0 T0:125.11 /245 @0:0 T1:20.98 /0 @1:0
    > 12:03:57.059: T:125.72 /245 B:29.76 /30 B@:0 @:0 T0:125.72 /245 @0:0 T1:20.98 /0 @1:0
    > 12:03:58.059: T:126.06 /245 B:29.63 /30 B@:0 @:0 T0:126.06 /245 @0:0 T1:20.98 /0 @1:0
    > 12:03:59.063: T:126.29 /245 B:29.51 /30 B@:0 @:0 T0:126.29 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:00.065: T:126.33 /245 B:29.51 /30 B@:0 @:0 T0:126.33 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:01.067: T:126.33 /245 B:29.39 /30 B@:0 @:0 T0:126.33 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:02.067: T:126.21 /245 B:29.27 /30 B@:0 @:0 T0:126.21 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:03.067: T:126.06 /245 B:29.15 /30 B@:0 @:0 T0:126.06 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:04.070: T:125.87 /245 B:29.02 /30 B@:0 @:0 T0:125.87 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:05.071: T:125.61 /245 B:28.90 /30 B@:0 @:0 T0:125.61 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:06.075: T:125.30 /245 B:28.90 /30 B@:0 @:0 T0:125.30 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:07.075: T:125.00 /245 B:28.66 /30 B@:0 @:0 T0:125.00 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:08.075: T:124.66 /245 B:28.66 /30 B@:0 @:0 T0:124.66 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:09.078: T:124.32 /245 B:28.54 /30 B@:0 @:0 T0:124.32 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:10.080: T:123.90 /245 B:28.41 /30 B@:0 @:0 T0:123.90 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:11.082: T:123.56 /245 B:28.29 /30 B@:0 @:0 T0:123.56 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:12.083: T:123.14 /245 B:28.17 /30 B@:0 @:0 T0:123.14 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:13.083: T:122.73 /245 B:28.17 /30 B@:0 @:0 T0:122.73 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:14.087: T:122.31 /245 B:28.05 /30 B@:0 @:0 T0:122.31 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:15.087: T:121.89 /245 B:27.93 /30 B@:0 @:0 T0:121.89 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:16.088: T:121.44 /245 B:27.80 /30 B@:0 @:0 T0:121.44 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:17.091: T:120.98 /245 B:27.80 /30 B@:0 @:0 T0:120.98 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:18.091: T:120.57 /245 B:27.68 /30 B@:0 @:0 T0:120.57 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:19.095: T:120.11 /245 B:27.56 /30 B@:0 @:0 T0:120.11 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:20.095: T:119.73 /245 B:27.32 /30 B@:0 @:0 T0:119.73 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:21.095: T:119.29 /245 B:27.32 /30 B@:0 @:0 T0:119.29 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:22.099: T:118.88 /245 B:27.20 /30 B@:0 @:0 T0:118.88 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:23.099: T:118.47 /245 B:27.07 /30 B@:0 @:0 T0:118.47 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:24.103: T:118.06 /245 B:27.07 /30 B@:0 @:0 T0:118.06 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:25.103: T:117.65 /245 B:26.95 /30 B@:0 @:0 T0:117.65 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:26.102: T:117.21 /245 B:26.95 /30 B@:0 @:0 T0:117.21 /245 @0:0 T1:20.98 /0 @1:0
    > 12:04:27.106: T:116.80 /245 B:26.83 /30 B@:0 @:0 T0:116.80 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:28.107: T:116.39 /245 B:26.71 /30 B@:0 @:0 T0:116.39 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:29.111: T:115.99 /245 B:26.71 /30 B@:0 @:0 T0:115.99 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:30.111: T:115.54 /245 B:26.59 /30 B@:0 @:0 T0:115.54 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:31.111: T:115.14 /245 B:26.46 /30 B@:0 @:0 T0:115.14 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:32.114: T:114.69 /245 B:26.46 /30 B@:0 @:0 T0:114.69 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:33.114: T:114.29 /245 B:26.34 /30 B@:0 @:0 T0:114.29 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:34.115: T:113.88 /245 B:26.34 /30 B@:0 @:0 T0:113.88 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:35.119: T:113.47 /245 B:26.22 /30 B@:0 @:0 T0:113.47 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:36.119: T:113.06 /245 B:26.22 /30 B@:0 @:0 T0:113.06 /245 @0:0 T1:21.10 /0 @1:0
    > 12:04:37.122: T:112.65 /245 B:26.10 /30 B@:0 @:0 T0:112.65 /245 @0:0 T1:21.10 /0 @1:0
  • Heaters are all ok and showing temp
  • Firmware also still says it is heating. It is just as not turning the heater on any more, no messages visible in output. Does lcd say something like defect/decoupled? I don't think so as log does not show anything.
    In any case it is a firmware settings issue and no server error.  What temperature manager are you using with which settings?
  • Heat manager 1 for extruders and heat manager 0 for bed. What heat manager do you recommend?
  • I use 1 or 3 for extruders, both work great if configured correctly. For 1 you can use M303 to find best parameter. Make sure max pwm are high enough to reach temperatures.
    what is strange here is that you are far away from normal control range, so no real reason to disable heater power here. What have you set as control range for heat managers? Default is 20°C I think, so should start at 225°C and be full power until then.
    Not sure which version you use, so maybe upgrade to dev version.
  • OK so no errors on LCD screen.
    All working now but if i stop a print the extruder and bed temp stay on, Should be set back to zero?
  • They only go to zero if you programmed it so.
    So set it in slicer end gcode to zero or in server job end/stop gcode.
  • Everything else good but now stops printing 1/4 way through stops heating see errors below any idea?
    > 21:33:11.274: ok 48837
    < 21:33:11.275: N638667 G1 X14.448 Y26.522 E2.1469
    > 21:33:11.281: T:219.57 /220 B:50.09 /50 B@:0 @:227 T0:219.57 /220 @0:227 T1:39.32 /0 @1:0
    > 21:33:11.281: ok 48838
    < 21:33:11.282: N638668 G1 X14.490 Y26.468 E2.1496
    > 21:33:11.282: ok 48839
    < 21:33:11.283: N638669 G1 X14.564 Y26.401 E2.1534
    > 21:33:11.284: ok 48840
    < 21:33:11.284: N638670 G1 X14.748 Y26.295 E2.1617
    > 21:33:11.294: ok 48841
    < 21:33:11.294: N638671 G1 X14.916 Y26.129 E2.1709
    > 21:33:11.302: ok 48842
    < 21:33:11.302: N638672 G1 X15.189 Y25.734 E2.1896
    > 21:33:11.314: ok 48842
    < 21:33:11.315: N638673 G1 X15.668 Y25.251 E2.2160
    > 21:33:11.430: SelectExtruder:1
    > 21:33:11.431: FlowMultiply:100
    > 21:33:11.442: Error:Format error
    < 21:33:11.657: Resend: N638667 G1 X14.448 Y26.522 E2.1469
    < 21:33:11.658: Resend: N638668 G1 X14.490 Y26.468 E2.1496
    > 21:33:11.658: Resend:48843
    < 21:33:11.658: Resend: N638669 G1 X14.564 Y26.401 E2.1534
    > 21:33:11.658: ok
    > 21:33:11.766: Resend:48843
    < 21:33:11.767: Resend: N638670 G1 X14.748 Y26.295 E2.1617
    > 21:33:11.767: ok
    < 21:33:11.767: Resend: N638671 G1 X14.916 Y26.129 E2.1709
    < 21:33:11.876: Resend: N638672 G1 X15.189 Y25.734 E2.1896
    > 21:33:11.876: Resend:48843
    < 21:33:11.876: Resend: N638673 G1 X15.668 Y25.251 E2.2160
    > 21:33:11.876: ok
    < 21:33:11.876: N638674 G1 X16.017 Y24.854 E2.2366
    > 21:33:11.877: ok 48843
    < 21:33:11.877: N638675 G1 X16.056 Y24.701 E2.2428
    > 21:33:11.878: ok 48844
    < 21:33:11.878: N638676 G1 X16.316 Y24.409 E2.2580
    > 21:33:11.878: ok 48845
    < 21:33:11.878: N638677 G1 X16.444 Y24.109 E2.2707
    > 21:33:11.878: ok 48846
    < 21:33:11.878: N638678 G1 X16.813 Y23.375 E2.3026
    > 21:33:11.879: ok 48847
    < 21:33:11.879: N638679 G1 X16.914 Y23.115 E2.3135
    > 21:33:11.879: ok 48848
    < 21:33:11.880: N638680 G1 X16.935 Y22.971 E2.3192
    > 21:33:11.883: ok 48849
    < 21:33:11.884: N638681 G1 X17.007 Y22.790 E2.3267
    > 21:33:11.884: ok 48850
    < 21:33:11.884: N638682 G1 X17.072 Y22.527 E2.3373
    > 21:33:11.884: ok 48851
    < 21:33:11.884: N638683 G1 X17.095 Y22.322 E2.3453
    > 21:33:11.884: ok 48852
    < 21:33:11.885: N638684 G1 X17.187 Y22.165 E2.3524
    > 21:33:11.887: ok 48853
    < 21:33:11.887: N638685 G1 X17.244 Y22.027 E2.3582
    > 21:33:11.888: ok 48854
    < 21:33:11.888: N638686 G1 X17.411 Y21.771 E2.3701
    > 21:33:11.888: ok 48855
    < 21:33:11.888: N638687 G1 X17.506 Y21.542 E2.3797
    > 21:33:11.891: ok 48856
    < 21:33:11.892: N638688 G1 X17.617 Y21.350 E2.3884
    > 21:33:11.892: ok 48857
    < 21:33:11.892: N638689 G1 X17.645 Y21.266 E2.3918
    > 21:33:11.892: ok 48858
    < 21:33:11.892: N638690 G1 X17.881 Y20.988 E2.4060
    > 21:33:11.893: ok 48859
    < 21:33:11.893: N638691 G1 X18.096 Y20.544 E2.4252
    > 21:33:11.893: ok 48860
    < 21:33:11.893: N638692 G1 X18.126 Y20.446 E2.4292
    > 21:33:11.895: ok 48861
    < 21:33:11.896: N638693 G1 X18.237 Y20.290 E2.4366
    > 21:33:11.896: ok 48862
    < 21:33:11.896: N638694 G1 X18.285 Y20.129 E2.4432
    > 21:33:11.896: ok 48863
    < 21:33:11.896: N638695 G1 X18.396 Y19.971 E2.4507
    > 21:33:11.905: ok 48864
    < 21:33:11.905: N638696 G1 X18.443 Y19.814 E2.4571
    > 21:33:11.921: ok 48865
    < 21:33:11.921: N638697 G1 X18.554 Y19.656 E2.4646
    > 21:33:11.932: ok 48866
    < 21:33:11.932: N638698 G1 X18.601 Y19.495 E2.4711
    > 21:33:11.937: ok 48867
    < 21:33:11.937: N638699 G1 X18.715 Y19.330 E2.4789
    > 21:33:11.945: ok 48868
    < 21:33:11.946: N638700 G1 X18.755 Y19.191 E2.4846
    > 21:33:11.953: ok 48869
    < 21:33:11.953: N638701 G1 X18.868 Y19.023 E2.4924
    > 21:33:11.974: ok 48870
    < 21:33:11.974: N638702 G1 X18.910 Y18.883 E2.4981
    > 21:33:11.982: Error:Wrong checksum
    < 21:33:12.197: Resend: N638695 G1 X18.396 Y19.971 E2.4507
    < 21:33:12.197: Resend: N638696 G1 X18.443 Y19.814 E2.4571
    > 21:33:12.197: Resend:48871
    < 21:33:12.198: Resend: N638697 G1 X18.554 Y19.656 E2.4646
    > 21:33:12.198: ok
    > 21:33:12.306: Resend:48871
    < 21:33:12.306: Resend: N638698 G1 X18.601 Y19.495 E2.4711
    > 21:33:12.307: ok
    < 21:33:12.307: Resend: N638699 G1 X18.715 Y19.330 E2.4789
    < 21:33:12.307: Resend: N638700 G1 X18.755 Y19.191 E2.4846
    > 21:33:12.308: ok 48871
    < 21:33:12.308: Resend: N638701 G1 X18.868 Y19.023 E2.4924
    > 21:33:12.308: ok 48872
    < 21:33:12.308: Resend: N638702 G1 X18.910 Y18.883 E2.4981
    > 21:33:12.308: ok 48873
    < 21:33:12.308: N638703 M105
    > 21:33:12.309: ok 48874
    < 21:33:12.309: N638704 G1 X19.065 Y18.673 E2.5083
    > 21:33:12.313: ok 48875
    < 21:33:12.314: N638705 G1 X19.104 Y18.360 E2.5205
    > 21:33:12.314: ok 48876
    < 21:33:12.314: N638706 G1 X19.221 Y18.202 E2.5282
    > 21:33:12.314: ok 48877
    < 21:33:12.314: N638707 G1 X19.259 Y17.894 E2.5403
    > 21:33:12.315: ok 48878
    < 21:33:12.315: N638708 G1 X19.377 Y17.740 E2.5478
    > 21:33:12.319: ok 48879
    < 21:33:12.319: N638709 G1 X19.416 Y17.425 E2.5602
    > 21:33:12.320: T:39.32 /0 B:49.97 /50 B@:255 @:0 T0:219.71 /220 @0:197 T1:39.32 /0 @1:0
    > 21:33:12.320: ok 48880
  • Yes, that is a communication error that some users frequently get
    What firmware read was interpreted as extruder switch. Please upgrade to latest dev firmware. We did some improvements on detecting this special error so it does not switch extruder so print survives.
  • Testing 1.0.0Dev with my working uploaded config.h file.
    Machine functions working ok but can not start a print.
    Machine says "Preparing Print" then gone nothing................................................................................................................................
  • My assumption is a error in file structure in model or print queue (/var/lib/Repetier-Server/printers/<slug>/models or jobs directory. Try deleting contents and restart server. If you are nice make a zip from it and then delete. If problem goes away, send us the zip so we can analyse what causes the problem so we can fix it.
  • Prints still stopping even with Dev FW i have this on 3 machines. If i disconnect it from the network will that fix it until v 0.8?
  • How do we come from print not starting to print stopping? Don't understand what your question is about.
  • Fault from 21st July as above communications fault still stops heaters and feeders even with Dev FW. If communications fault will running it without a network fix it? Any idea when V0.8 will be ready?
  • I have the same pro licence key running on all 3 machines because i just copied the .img could that be causing the communication format error causing it to stop and start heaters and feeding during a print leaving big lines and missing layers?
  • Current guess for 0.8 is end of month, but only if new features work as I want them to.
    "If communications fault will running it without a network fix it?" ?????????
    network is only required for sending gcode and starting jobs, afterwords you can disconnect or anything you like. If you use wlan and it is a very unstable connection you might be in trouble that your reconnect requests take to much cpu time causing some pauses, but in general it should continue printing.
    Printing only relies on usb-serial connection. Here electrical noise and voltage fluctuations can cause a stop of communication, everything else makes print continue sooner or later. If print continues without heaters you might have a decoupled extruder detected and firmware did go to dry run mode.
    Copying img files is no problem as long as they use dhcp to get different ip numbers.
