Auto bed leveling with inductive sensor
I have a cartesian printer on which I used an inductive sensor for both Y-min sensing and auto bed leveling.
This is described for Marlin firmware and works ok.
Since repetier firmware has a very good implementation for a filament sensor i changed to repetier firmware.
I only have problems now with auto bed leveling.
As far as I can discover autobed leveling in repetier works in a different manner, in which seperate z-min endstops and z-probe are used. Am I correct?
Is it possible to use the inductive sensor in repetier in the same manner as in Marlin?
Also, is it possible to change to 4 probing positions instead of 3?
I have an Inductor Sensor.
Can you help me please? I am nob at this.
allows moving to negative values in our firmware.
But you need to send it as G1 command - host will not send it with move buttons.
