Ineffective autolevel results
I have a delta printer running repetier .91 with a capacitive Z-probe.
The problem I am having is that after running autolevel with G32, small prints in the center of my bed stick well but larger prints drive the nozzle into the bed or have it raised 1-2mm above the bed, it seems like the autolevel script does not accurately calculate the tilt of my bed.
There are a few things that might be causing this issue:
I don't know if the horizontal radius or diagonal rod length is perfectly asccurate, I am fairly sure they are close as when I level the bed manually using x,z,y offsets I get fairly consistent results.
I am a little confused as to how the x,y offset from the probe to the nozzle works, if it is +20mm from the nozzle in the Y direction, is the offset +20mm or -20mm.
my probe seems quite reliable and is fixed in place so its unlikely that there is any mechanical error there.
I am using a 6mm thick float glass mirror as my print surface so it is extremely planar, the discrepancy is not accounted for by an uneven print surface.
Where can I get a download of .92 there is only .91 listed on the firmware page?
I got repetier .92 running but the .ino file doesn't contain any G codes beyond the usualy G29, G30, and G32 for autoleveling the bed, I can't see a code for running a "bed correction" and google doesn't seem to be turning up any results tutorial-wise
From the description in the configuration wizard, it sounds like the auto-correct runs a grid rather than a 3 point probe, g29 and 32 both run 3 point probes currently.
here are the G-codes from my .ino
- G0 -> G1
- G1 - Coordinated Movement X Y Z E
- G4 - Dwell S<seconds> or P<milliseconds>
- G20 - Units for G0/G1 are inches.
- G21 - Units for G0/G1 are mm.
- G28 - Home all axis or named axis.
- G29 S<0..2> - Z-Probe at the 3 defined probe points. S = 1 measure avg. zHeight, S = 2 store avg zHeight
- G30 P<0..3> - Single z-probe at current position P = 1 first measurement, P = 2 Last measurement P = 0 or 3 first and last measurement
- G31 - Write signal of probe sensor
- G32 S<0..2> P<0..1> - Autolevel print bed. S = 1 measure zLength, S = 2 Measue and store new zLength
- G90 - Use absolute coordinates
- G91 - Use relative coordinates
- G92 - Set current position to cordinates given
- G131 - set extruder offset position to 0 - needed for calibration with G132
- G132 - calibrate endstop positions. Call this, after calling G131 and after centering the extruder holder.
I got that working with the M323 command but how do I incorporate the distortion maxtrix? The host kicks out this after running the g29 command, but the performance of the printer seems unchanged:
22:15:18.730 : Z-probe:12.52 X:-100.00 Y:100.00 zCorr:0.00
22:15:29.389 : Z-probe:12.79 X:-50.00 Y:100.00 zCorr:0.00
22:15:40.171 : Z-probe:12.80 X:0.00 Y:100.00 zCorr:0.00
22:15:51.031 : Z-probe:12.93 X:50.00 Y:100.00 zCorr:0.00
22:16:02.062 : Z-probe:13.15 X:100.00 Y:100.00 zCorr:0.00
22:16:14.313 : Z-probe:12.68 X:-100.00 Y:50.00 zCorr:0.00
22:16:24.939 : Z-probe:12.61 X:-50.00 Y:50.00 zCorr:0.00
22:16:35.550 : Z-probe:12.64 X:0.00 Y:50.00 zCorr:0.00
22:16:46.254 : Z-probe:12.76 X:50.00 Y:50.00 zCorr:0.00
22:16:57.068 : Z-probe:12.91 X:100.00 Y:50.00 zCorr:0.00
22:17:09.069 : Z-probe:12.45 X:-100.00 Y:0.00 zCorr:0.00
22:17:19.522 : Z-probe:12.47 X:-50.00 Y:0.00 zCorr:0.00
22:17:29.991 : Z-probe:12.48 X:0.00 Y:0.00 zCorr:0.00
22:17:40.508 : Z-probe:12.58 X:50.00 Y:0.00 zCorr:0.00
22:17:51.165 : Z-probe:12.76 X:100.00 Y:0.00 zCorr:0.00
22:18:02.933 : Z-probe:12.15 X:-100.00 Y:-50.00 zCorr:0.00
22:18:13.137 : Z-probe:12.28 X:-50.00 Y:-50.00 zCorr:0.00
22:18:23.451 : Z-probe:12.36 X:0.00 Y:-50.00 zCorr:0.00
22:18:33.874 : Z-probe:12.48 X:50.00 Y:-50.00 zCorr:0.00
22:18:44.375 : Z-probe:12.56 X:100.00 Y:-50.00 zCorr:0.00
22:18:55.796 : Z-probe:11.67 X:-100.00 Y:-100.00 zCorr:0.00
22:19:05.626 : Z-probe:11.99 X:-50.00 Y:-100.00 zCorr:0.00
22:19:15.673 : Z-probe:12.13 X:0.00 Y:-100.00 zCorr:0.00
22:19:25.878 : Z-probe:12.31 X:50.00 Y:-100.00 zCorr:0.00
22:19:36.207 : Z-probe:12.37 X:100.00 Y:-100.00 zCorr:0.00
22:19:42.458 : Info:Distortion correction matrix:
22:19:42.458 : 0, -27, -28, -41, -63
22:19:42.458 : -16, -9, -12, -24, -39
22:19:42.458 : 6, 4, 3, -6, -24
22:19:42.458 : 36, 23, 15, 3, -4
22:19:42.458 : 84, 52, 38, 20, 14
