MAX31865 support (pt100/pt1000)
hi repetier,
dont know if you are already on it but maby its a nice thing to have for the radds or other due board users.
i know that the arduino library already exists
SUPPORT_MAX31855
which is similar. You could use that as an example on how to do it. I guess they only differ in formula.
the only thing i get is watchdog reset, no other communication.
runned it with only the source code of the max31865 and it works so i know that its not a pin issue.
i think i need some extra information about how the hall:spi works.
also is there a way to configure the max31865 on when the due first get power? now i have it before i get temperature readout so everytime its get called it will configure the max31865 first (has to do with the 3 or 4/2 wire setup)
im not a very skilled programmer so any help would be really helpfull.
has anyone made progress regarding the max 31865 amplifier? I would realy like to upgrade my Printer with a RADDS 1.5 controller to use a PT100 sensor.
Cheers !
