XYZ endstops hit
I'm using GT2560 Georges Setup for Geeetech Prusa i3 Pro B firmware and it is so far the only firmware that seems to work in manual control except for... When I manually move my XYZ axis they will not move in the negative direction, the error is echo:endstops hit: X or Y or Z depending on the axis I use.
Does anyone know a fix for this?
