Zprobed G32 makes zero Z to be 2mm above from bed. Z-probe height is measured with G30.
Hi! I measured Z-Probe height with G30 command:
G1 Z4.6 ; real bed level, nozzle is 0.1 mm above from bed
G1 Z24.6 ; prepare for z-probing, just go up 20 mm from bed
G30 ; this shows 20mm in result, so Z-Probe height is correct
But when I do G32, then it measures my bed and makes Z zero to be about 2 mm above from bed. I suppose this is some tuning, maybe coating, maybe something similar, but I checked everything and have not found what it can be. I solved this by increasing Z-Probe height, but I do not think that this is the right way.
My EEPROM (Z-Probe height is already increased):
<epr pos="1024" type="3" value="0.000">Coating thickness</epr>
<epr pos="808" type="3" value="10.100">Z-probe height</epr>
<epr pos="929" type="3" value="20.000">Max. z-probe - bed dist.</epr>
Firmware:
#define Z_PROBE_Z_OFFSET 0
#define Z_PROBE_Z_OFFSET_MODE 1
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 30
#define Z_PROBE_SWITCHING_DISTANCE 3
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 9.1
#define BED_LEVELING_METHOD 0
My startup and measuring code:
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstop (I do not have max endstop)
G1 Z30.0 ; Go up because endstop is lower than bed
M322 ; Do not remember why I included this
G32 S3 ; Make a measurement
Full eeprom and firmware configuration files
Firmware:
Am I right that this determining zProbeHeight method is correct?
Am I right that G32 will work correctly with such printer configuration?
(I suppose that one of these assumptions is false. Which one? What should I do?)
I hope I explained everything understandable
