`.text' will not fit in region `text' during compile
I wnet back through the configuration tool to add the diisplay information for my board rather than try and add the info myself. Now when I compile the code I get this message. Once again, not a programmer - no clue how to resolve. Help appreciated.
Full text of errrors:
Arduino: 1.6.9 (Windows XP), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
c:/program files/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: C:\DOCUME~1\John\LOCALS~1\Temp\build1d76ff8a31b0f78df26120a58e13e379.tmp/Repetier.ino.elf section `.text' will not fit in region `text'
c:/program files/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: region `text' overflowed by 7708 bytes
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Sanguino.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
exit status 1
collect2.exe: error: ld returned 5 exit status
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Next question - again pardon my complete ignorance.
Is the firmware loaded to the chip via the USB interface? The Arduino ISP is not needed for that step?
I'm getting the old can't sync with the chip error trying to upload the firmware via the USB. I'll change the upload speed to see if there is a mismatch there.
