Preview placement after slice at 0,0
After upgrading from 1.6.0 -> 1.6.1 my previews after slicing with Curaengine are placed and printed at 0,0 in the lower left corner.
Printing at 0,0 is impossible!
Changed different settings in the printer configuration menu without success and made a fresh install with deleting .mono and .local/share/RepetierHost directories.
The Problem still exist.
Sliced with slicer, object is correctly placed in midposition.
I deleted all directories and config's like .cura, .local/share/Repetier, .mono and the unzip directory.
I start repetierhost 1.6.1 get the default preview and slice it without configuring my printer, just use CuraEngine instead of Slicer.
The Objekt ist placed in the lower left corner, with 50% outside of the printroom/bed.
The Log:
16:26:15.785 : CuraEngine command:/home/eike/Downloads/system_sparkcube/RepetierHost/plugins/CuraEngine/CuraEngine -p -v -c "/home/eike/.local/share/RepetierHost/cura.ini" -s posx=0 -s posy=0 -o "/home/eike/.local/share/RepetierHost/composition.gcode" "/home/eike/.local/share/RepetierHost/composition0.stl"
16:26:15.795 : <CuraEngine> Cura_SteamEngine version 14.09
16:26:15.796 : <CuraEngine> Copyright (C) 2014 David Braam
16:26:15.796 : <CuraEngine> This program is free software: you can redistribute it and/or modify
16:26:15.796 : <CuraEngine> it under the terms of the GNU Affero General Public License as published by
16:26:15.796 : <CuraEngine> the Free Software Foundation, either version 3 of the License, or
16:26:15.796 : <CuraEngine> (at your option) any later version.
16:26:15.796 : <CuraEngine> This program is distributed in the hope that it will be useful,
16:26:15.796 : <CuraEngine> but WITHOUT ANY WARRANTY; without even the implied warranty of
16:26:15.796 : <CuraEngine> MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
16:26:15.796 : <CuraEngine> GNU Affero General Public License for more details.
16:26:15.796 : <CuraEngine> You should have received a copy of the GNU Affero General Public License
16:26:15.796 : <CuraEngine> along with this program. If not, see <http://www.gnu.org/licenses/>.
16:26:15.796 : <CuraEngine> Default config 'default.cfg' not used
16:26:15.796 : <CuraEngine> Config(/home/eike/.local/share/RepetierHost/cura.ini):L13: Failed to set 'skinSpeed' to '45'
16:26:15.796 : <CuraEngine> Failed to read config '/home/eike/.local/share/RepetierHost/cura.ini'
16:26:15.796 : <CuraEngine> Loading /home/eike/.local/share/RepetierHost/composition0.stl from disk...
What can I do? I use Ubuntu 15.10 latest patches installed.
And Cura from Ultimaker is installed but not used, because I also have an Ultimaker.
Repetier Host 1.6.1 with bundled curaengine, Ubuntu 14.04.
$HOME/.local/share/RepetierHost deleted, $HOME/.mono/registry/CurrentUser/software/repetier deleted, repetier install dir deleted, gunzip 1.6.1, did sudo ./createDesktopIcon.sh, adjusted owner and execute rights of just created .desktop file, copied it to desktop. Launched Repetier Host.
Tried slicing of example object with all default settings (hit only 'Slice with CuraEngine')
Got error L13: Failed to set 'skinSpeed' to '45' and center of sliced object placed at 0,0.
So what disturb curaengine on *out of box* Repetier Host?
I agree the real problem is curaengine ignoring .ini file due to fail on line 13. But how it can be adjusted?
My log show the same error in the ini file and the same thing: the object sliced with cura is always on 0,0 after the slice.
I've checked my permissions and are fine to me, I've also set cura.ini and composition* to 777 just to be sure.
They have the same permissions of slic3r, but slic3r works.
Here's the content of cura.ini
[blackman@Vega Repetier]$ cat cura.ini
layerThickness = 200
initialLayerThickness = 300
filamentDiameter = 1750
filamentFlow = 100
extrusionWidth = 400
layer0extrusionWidth = 400
insetCount = 2
infillOverlap = 15
initialSpeedupLayers = 4
initialLayerSpeed = 30
printSpeed = 40
infillSpeed = 60
skinSpeed = 30
inset0Speed = 30
insetXSpeed = 40
moveSpeed = 150
fanSpeedMin = 50
fanSpeedMax = 100
supportAngle = -1
supportEverywhere = 0
supportLineDistance = 2666
supportXYDistance = 700
supportZDistance = 150
supportExtruder = -1
retractionAmount = 4000
retractionSpeed = 40
retractionMinimalDistance = 1500
retractionAmountExtruderSwitch = 16000
retractionZHop = 0
minimalExtrusionBeforeRetraction = 20
enableCombing = 1
multiVolumeOverlap = 0
objectSink = 0
minimalLayerTime = 5
minimalFeedrate = 10
coolHeadLift = 0
perimeterBeforeInfill = 1
extruderOffset[0].X = 0
extruderOffset[0].Y = 0
fixHorrible = 1
fanFullOnLayerNr = 2
supportType = 0
infillPattern = 0
sparseInfillLineDistance = 4000
downSkinCount = 3
upSkinCount = 3
skirtDistance = 3000
skirtLineCount = 1
skirtMinLength = 150000
gcodeFlavor = 0
spiralizeMode = 0
enableOozeShield = 0
autoCenter = 0
startCode = """
; Default start code
G28 ; Home extruder
G1 Z15 F100
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
M190 S50
; Activate all used extruder
M104 T0 S210
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
M109 T0 S210
endCode = """
; Default end code
;G1 X0 Y0 Z130 ; Get extruder out of way. Uncomment to use!
M107 ; Turn off fan
; Disable all extruder
G91 ; Relative positioning
T0
G1 E-1 ; Reduce filament pressure
M104 T0 S0
M140 S0 ; Disable heated bed
M84 ; Turn steppers off
preSwitchExtruderCode = """
postSwitchExtruderCode = """
AND if I delete cura.ini it gets created exactly the same again
Please HELP !!
Both are on Fedora 22-23, 64 bit machines
Default CuraEngine with Repetier but I have tested also other version.
While exploring about your question I think I've found the bug.
I have the Cura Plugin directory with CuraEngine CuraEngine32 and CuraEngine64. I assume that CuraEngine is a wrapper?
If I delete CuraEngine and symlink directly the 32 or 64 bit filename, both works
Directory RepetierHost/plugins/CuraEngine
mv CuraEngine CuraEngine.old
ln -s CuraEngine64 CuraEngine
WORKS
ln -s CuraEngine32 CuraEngine
WORKS TOO
mv CuraEngine.old CuraEngine
DOES NOT WORK
I had this problem for months :-|
I am going to try this solution at home tonight to see if it works with the 1.6.1 too
The "hack" works also there.
In my system it does not looks like a copy of the two, the file size is different..
$ pwd
/home/blackman/RepetierHost/plugins/CuraEngine
$ ls -l
totale 7080
lrwxrwxrwx 1 blackman blackman 12 7 giu 10.04 CuraEngine -> CuraEngine64
-rwxr-xr-x. 1 blackman blackman 1965872 2 lug 2015 CuraEngine32
-rwxr-xr-x. 1 blackman blackman 2535136 4 lug 2015 CuraEngine64
-rw-r--r--. 1 blackman blackman 198144 23 set 2015 CuraEngine.dll
-rwxr-xr-x. 1 blackman blackman 2531049 4 lug 2015 CuraEngine.old
$ diff CuraEngine.old CuraEngine32
I file binari CuraEngine.old e CuraEngine32 sono diversi (different)
$ diff CuraEngine.old CuraEngine64
I file binari CuraEngine.old e CuraEngine64 sono diversi
I am going to check the configureFirst.sh and report.
Thanks for this amazing software.
The point is that I never launched it and looks like if you just download the precompiled version it's broken.
Perhaps this should be checked in repetierHost lanuch script? I am discovering just now it was written on the README file...
