SD read error (Firmware-0.92.9, ramps 1.4)
Good afternoon.
After some time, I have a problem. The printer stops printing error "SD read error".
That log printing from a memory card from Pronterface program.
SD printing byte 103024/11409637
ok 0
Unknown command:M106  S255
ok 0
SD printing byte 104035/11409637
ok 0
ok 0
SD printing byte 107378/11409637
ok 0
ok 0
SD printing byte 110746/11409637
ok 0
ok 0
SD printing byte 111782/11409637
ok 0
ok 0
SD printing byte 112706/11409637
ok 0
ok 0
SD printing byte 113558/11409637
ok 0
Unknown command:M107
ok 0
SD printing byte 114743/11409637
ok 0
ok 0
SD printing byte 132902/11409637
ok 0
ok 0
SD printing byte 135076/11409637
ok 0
SD read error
Error:SD error did not recover!
[ERROR] Error:SD error did not recover!
Done printing file
Print ended at: 13:00:07 and took 0:16:27
[ERROR] Traceback (most recent call last):
  File "printrun\printcore.pyc", line 241, in _readline
  File "printrun\pronterface.pyc", line 1720, in recvcb
  File "printrun\pronterface.pyc", line 1749, in waitforsdresponse
  File "printrun\pronterface.pyc", line 1511, in endcb
  File "printrun\pronsole.pyc", line 1190, in endcb
AttributeError: 'NoneType' object has no attribute 'filament_length'
  • UPD. I tried different memory card. The problem is repeated.
  • M106 is ok, you compiled without fan support but slicer uses it.
    Does the error always happen on the same position on both cards? Or is it a random position so it is more a real reading problem? In that case make sure the cable is shielded and does not come near powered lines like heaters/steppers. Here crosstalk can easily influence reading.
  • Its hardware problem. I'm change "smart controller" and all work good. Pls close topic.
  • Hi, I have  the same error prompt  on everytime I try to print by SD card, o every gcode file.
    I don't understand the ZMan answer.
    Can you help me?
