crash when trying to type a second EEPROM parameter value
Using repetierHostLinux_6.tgz, V1.0.6, on LInux Mint 16, and mono3.10.0-0xamarin2, I get a crash when trying to type in an EEPROM setting the second time.  With printer connected, click Config->"Firmware EEPROM Configuration", scroll to Extr.1 X-offset[steps],  click twice in the value box, type a value, click OK.  This works once.  The second try, on the second click in the value box always crashes with:
rodney@allegheny:~/shop/3dprinting/BootsIndustries/RepetierHost$ Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 14: reading configurations from ~/.fonts.conf is deprecated.
System.ObjectDisposedException: The object was used after being disposed.
  at System.Windows.Forms.Control.CreateHandle () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.TextBoxBase.CreateHandle () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.CreateControl () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.SetVisibleCore (Boolean value) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.set_Visible (Boolean value) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:set_Visible (bool)
  at System.Windows.Forms.DataGridView.BeginEdit (Boolean selectAll) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.SetCurrentCellAddressCore (Int32 columnIndex, Int32 rowIndex, Boolean setAnchorCellAddress, Boolean validateCurrentCell, Boolean throughMouseClick) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.OnMouseDown (System.Windows.Forms.MouseEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WmLButtonDown (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.DataGridView.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
  • That is a incompatibility of mono causing the crash. We need to completely rewrite the table routine. Will be fixed in one of the next releases.
  • OK, thanks.  Is there an earlier mono version that would get me going quickly?
  • No, older versions even won't start.
