Melzi+ reprap smart controller
when i chose smart controller in configurator and then manually edit pins in ui.h arduino says that
section .text will not fit in region text
region text overflowed by 7084 bytes
as far as i understand that means firmware now weights more than 128kb
is there any chance to make it work?
it works perfectly on marlin
  • No it means predefined values are > 64KB. Normally happens when you have selected too many languages. Try deselecting a few languages.
  • I only selected english
