3,3v Signal Voltage, and motor drivers need 5v
Hi, so this little problem has just come to my attention. And a possible solution has come up in the smoothieboard documentation.
But it mentions something about changing pins to open drain, is this something i have to do anything with in repetier firmware?
Or if it will work at all?
Problem would be to go higher than 5V then additional resistors would be necessary in each Signal line.
I cannot say something to pinnumbers, don´t have Radds
I will have to try with correct pinout and see if my driver work with 3.3v it it does it will surely make this easier
A level shifter will do the job nicely if it doesn't ☺
