some minor bugs
Hi there,
first off im very very pleased with the 0.75 update especially the https. Great work.
now i found some minor bugs within the new update.
1. when making a user with no rights (every checkmark unchecked) it wil not allow you to login on this user. only when the checkmark "user can print" enabled it wil log you in
2. i think this is more of a personal thingy but that you now can make your own QR code you also need to specify a port. is there a way to disable the port because i dont use it.
3. the time on the graph from the temp sensors doesnt mach up with the actual time (2 hour differents). when moving over the line a nice popup wil tell you what the temp was on this exact moment, the time in this popup does mach with the actual time. dont know if this is a server problem or just my pi
this is what i got so far.. dont rush it... just keep up the good work
No, this is on the web frontend, the temp graph is 8 hours behind, which seeing as I am UTC+8, that means it's showing UTC?
The Uploaded file timestamps are correct
The print progress will look like this (when local time is 22:00:
ETA in HOST will say -46 seconds
