Z Probing on Tronxy Melzi 2.0 whatever......
Hey its me again, since several Days im trying to get my Z Probe working.
The actutal state is that my probe is reacting to H and L. Z Axis directions fit. X and Y endstops working correct.
But my Z Home via Repetier Host isnt working.
Maybe you guys could help me....
would be nice, i dont have a clear overview right now it is full with endstops in my head.
heres my configuration.h
#define NUM_EXTRUDER 1
#define MOTHERBOARD 63
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#undef Z_MIN_PIN
#define Z_MIN_PIN ORIG_Z_MAX_PIN
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 210
#define Y_MAX_LENGTH 210
#define Z_MAX_LENGTH 210
#define X_MIN_POS 0
#define Y_MIN_POS -5
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 400
#define MAX_FEEDRATE_Y 400
#define MAX_FEEDRATE_Z 4
#define HOMING_FEEDRATE_X 100
#define HOMING_FEEDRATE_Y 100
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 1 // time in microseconds
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS  -1
#define SERVO1_NEUTRAL_POS  -1
#define SERVO2_NEUTRAL_POS  -1
#define SERVO3_NEUTRAL_POS  -1
#define UI_SERVO_CONTROL 0
#define FAN_KICKSTART_TIME  200
        #define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET -43
#define Z_PROBE_Y_OFFSET 18
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 60
#define Z_PROBE_SWITCHING_DISTANCE 2
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 4
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 60
#define Z_PROBE_Y1 60
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 60
#define Z_PROBE_X3 60
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
  • The one who gets my machine to work will get a donation. Please help
  • #define MAX_FEEDRATE_X 400
    I think your z feedrate is to low
  • Sry, that didnt helped. Still no working Z home
  • #define MIN_HARDWARE_ENDSTOP_Z false -> true
    #define ENDSTOP_Z_MAX_INVERTING true ----> false
  • edited April 2016
    Ok, shogun please send me your paypal adress.
    Another Question:
    How can i make repetier host safe z homing in mid of the bed. My probe is sitting on the left of my nozzle so it tries to z home where it cant home.
    I already wrote in config.h
    #define ZHOME_X_POS 105
    #define ZHOME_Y_POS 105
  • Another Problem:
    Managed to home z with this one :
     G1 X105 Y105 F5000
    G28 Z0
    But the Problem is that my probe triggers, goes up and then normally down and crashes into the bed
  • Fixed Height:
    G29 Gives me this one
    RECEIVED: fatal:G29 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
  • Nevermind fuck autoleveling went back to normal. thx everyone who some tthoughts about it
  • edited April 2016
    If you write G28 Z0   you go to the point you want to figure out with Z-Probe.
    write Z28 Z instead.
  • Sorry Typo..   i meant G28 Z
  • G29 fail is probably because you start autolevel too low, Z probe is already active.
    head crash after Z home is because you have set "#define Z_PROBE_BED_DISTANCE 10".. It will try to go to 10mm lower after homing Z, because it thinks that Z probe triggers at Z=10! I had the same problem. I have set that value to 0, then use "Z_PROBE_SWITCHING_DISTANCE" to set the actual offset between probe and bed. I'm not sure if this is correct way, but seems to work.
    You can change those values from the EEPROM too, no need to recompile.
    Then i also defined "#define ENDSTOP_Z_BACK_ON_HOME 10".. after Z home, it will lift Z by 10mm, which is high enough to deactivate the probe and G32 works.
    I home and autolevel with these commands:
    G28
    g1 x40 y40
    G32
    The g1 is needed because G32 first goes Z_PROBE_X_OFFSET to the left, banging the x min endstop..
    G28 homes Z at xmin/ymin, make sure you are above the bed there.
