Can´t upload firmware, wheres the error dont get it
Hey everyone, trying to upload my z probe autolevel firmware.
s.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Melzi 1284p 16mhz"
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Repetier.cpp.elf section .text will not fit in region text
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: region text overflowed by 72 bytes
So its too large, how can i make it fit so that i can upload it.
just chaged smthg in this segment but i cant find a solution:
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -30
#define Z_PROBE_Y_OFFSET -30
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 100
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 2
#define Z_PROBE_START_SCRIPT "G28 Y0 X0\n G1 X-40\n G28 Z0\n G1 Z5\n"
#define Z_PROBE_FINISHED_SCRIPT "G28 X0 Y0"
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 10
#define Z_PROBE_Y1 10
#define Z_PROBE_X2 170
#define Z_PROBE_Y2 10
#define Z_PROBE_X3 10
#define Z_PROBE_Y3 170
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
regards
Peter
  • You need to disable all unneeded features if you use such small controllers. LCD is big, sd card is big. G2/G3 support gives you some byte as well.
    EEPROM is also big but you want this for autoleveling.
  • Where is the specified line in conf.h ? sorry im noob :/
  • to disable the sd card i mean
  • As nob you bette ruse the online config tool. Sd is disabled until you enable it or add a display with sd card in which case it is always enabled. you would then need to edit ui.h to remove the enable command in the section for your display.
