LOTS of error messages when trying to verify firmware
Hello,
So do I scrap my Melzi board and use a RAMPS instead? LOL, seriously though. I'm getting a LOT of error messages when trying to verify the repetier firmware for a delta 3d printer using a melzi V3D board. Everything seems to be fine but then I am receiving error after error for settings I either know nothing about or that shouldn't really need redefining either. However, there appear to be a lot of anomalous pin settings that are not given a general setting and require me to change them all as they have no presets? Very frustrating as it has taken me a long time to get to this point only to have even more errors pop up. If anyone is able to tell me what is going on here or if there is a simple solution it would be greatly appreciated!
Pert of the error message(s) are as follows:
________________________________________________
Board Sanguino:Sanguino:atmega1284m doesn't define a 'build.board' preference. Auto-set to: SANGUINO_ATMEGA1284M
Board Sanguino:Sanguino:atmega12848m doesn't define a 'build.board' preference. Auto-set to: SANGUINO_ATMEGA12848M
Board Sanguino:Sanguino:atmega1284 doesn't define a 'build.board' preference. Auto-set to: SANGUINO_ATMEGA1284
Board Sanguino:Sanguino:atmega644 doesn't define a 'build.board' preference. Auto-set to: SANGUINO_ATMEGA644
In file included from sketch\HAL.h:77:0,
from sketch\Repetier.h:264,
from sketch\ui.cpp:20:
sketch\ui.h: In function 'void ui_init_keys()':
fastio.h:34: error: 'DIO52_DDR' was not declared in this scope
#define _SET_INPUT(IO) do {DIO ## IO ## _DDR &= ~MASK(DIO ## IO ## _PIN); } while (0)
uint8_t entType = HAL::readFlashByte((const prog_char*)&(ent->menuType));// 0 = Info, 1 = Headline, 2 = submenu ref, 3 = direct action command
ui.cpp:2087: error: expected ')' before 'const'
exit status 1
_____________________________________________________
Sigh.... So if anyone can make any sense of why I'm expected to redefine some of these pin settings or why this build.boards and DIO error swarms keep popping up, please let me know! Thank you!
exit status 1
sketch\fastio.h:54:26: note: in expansion of macro '_SET_INPUT'
#define SET_INPUT(IO) _SET_INPUT(IO)
sketch\ui.h:233:50: note: in expansion of macro 'SET_INPUT'
#define UI_KEYS_INIT_CLICKENCODER_LOW(pinA,pinB) SET_INPUT(pinA);SET_INPUT(pinB); PULLUP(pinA,HIGH);PULLUP(pinB,HIGH);
sketch\ui.h:824:3: note: in expansion of macro 'UI_KEYS_INIT_CLICKENCODER_LOW'
UI_KEYS_INIT_CLICKENCODER_LOW(UI_ENCODER_A,UI_ENCODER_B); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
fastio.h:34: error: 'DIO52_PIN' was not declared in this scope
sketch\fastio.h:17:30: note: in definition of macro 'MASK'
#define MASK(PIN) (1 << PIN)
fastio.h:34: error: 'DIO50_DDR' was not declared in this scope
sketch\ui.h:233:66: note: in expansion of macro 'SET_INPUT'
fastio.h:34: error: 'DIO50_PIN' was not declared in this scope
sketch\ui.cpp:451:5: note: in expansion of macro 'WRITE'
WRITE(UI_DISPLAY_ENABLE_PIN, LOW);
fastio.h:29: error: 'DIO44_WPORT' was not declared in this scope
#define _WRITE(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
sketch\fastio.h:48:25: note: in expansion of macro '_WRITE'
#define WRITE(IO, v) _WRITE(IO, v)
sketch\ui.cpp:458:5: note: in expansion of macro 'WRITE'
WRITE(UI_DISPLAY_D4_PIN, c & 0x01);
fastio.h:29: error: 'DIO44_PIN' was not declared in this scope
sketch\ui.cpp: In member function 'void UIDisplay::nextPreviousAction(int8_t)':
ui.cpp:2083: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
uint8_t mtype = HAL::readFlashByte((const prog_char*)&(men->menuType));
ui.cpp:2083: error: expected primary-expression before 'const'
ui.cpp:2083: error: expected ')' before 'const'
ui.cpp:2087: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
ui.cpp:2087: error: expected primary-expression before 'const'
Any thoughts or ideas on this?? It looks rather out of control when everything otherwise appeared to be all set
IO Pins highest number is 31 for this Controller
check your Pinlist seems you have a mismatch there. how did you configure Firmware?
Unfortunately I purchased my 3D printer as a kit that was supposed to have the firmware already pre-loaded and configured, which it was not. So now I am going through the process of manually configuring my own firmware due to obvious stop issues locking out a motor, LCD display not working, etc. Very annoying since the vendor is seemingly doing everything they can to not just send me a copy of the firmware so I can look it over - make necessary mods - then upload it to the machine.
Another problem is that I have no clue what to set my pin settings to, is there a tutorial or area where this is explained in detail? Also, if I am designating the correct board type, should these issues remove themselves? Thank you!
exec: "-w": executable file not found in %PATH%
Error compiling for board Sanguino W/ ATmega1284p 16mhz.
Any thoughts on how I can fix these problems?
Also, it appears the changes made to the hardware folder ARE tracked by arduino in a log file within that folder. So by uninstalling and reinstalling then adding back my old sanguino folder it took care of the missing boards problem as well. That info might be of use in the future, LOL
Thanks again!
