Melzi v2 with repetier firmware
I bought a printer Hsine Prusa i3 with melzi configured with the original firmware repetier. there is no problem to export the firmware of the card (EPR file). for updating firmware, you have to put the JP14 to "ON" and JP15 to "USB". Copy sanguino driver "atmega1284.name = 16MHz Melzi 1284p" in "C: \ Program Files (x86) \ Arduino \ hardware". In Device Manager, must identify the port on the card. In Arduino IDE, select the map "Melzi 16MHz 1284p", select the port. Now when I start the upload of the firmware marlin, the message "avrdude: stk500_getsync (): not in sync: resp = 0xAD" appears. it seems that many people are the problem. Should I use "Atmel April Programer AVRISP XP MKII" erase the bootloader and flash then upload the bootloader and marlin? Since November 2015, I can not to change the printer by adding "1 - LJC18A3-H-Z _BX". I'm really disgusting
how did you burn the bootloader and load firmware to the board ? .... could you upload a vedio of the process please ... because i got the same problem and my printer is dead for two months now
thanks in advance
