won't compile - 'THERMOCOUPLE_1_PIN' was not declared in this scope
Hello, I am trying to compile repetier ARM with pinout for RAMPS-FD v2. created with online configurator but will not compile - errors below
In file included from sketch/Repetier.h:198:0,
from sketch/Extruder.cpp:22:
Configuration.h:74: error: 'THERMOCOUPLE_1_PIN' was not declared in this scope
#define EXT0_TEMPSENSOR_PIN THERMOCOUPLE_1_PIN
sketch/Repetier.h:401:29: note: in expansion of macro 'EXT0_TEMPSENSOR_PIN'
#define EXT0_ANALOG_CHANNEL EXT0_TEMPSENSOR_PIN
sketch/Repetier.h:512:33: note: in expansion of macro 'EXT0_ANALOG_CHANNEL'
#define ANALOG_INPUT_CHANNELS {EXT0_ANALOG_CHANNEL EXT1_ANALOG_CHANNEL EXT2_ANALOG_CHANNEL EXT3_ANALOG_CHANNEL EXT4_ANALOG_CHANNEL EXT5_ANALOG_CHANNEL BED_ANALOG_CHANNEL THERMO_ANALOG_CHANNEL KEYPAD_ANALOG_CHANNEL}
sketch/Extruder.cpp:44:47: note: in expansion of macro 'ANALOG_INPUT_CHANNELS'
const uint8 osAnalogInputChannels[] PROGMEM = ANALOG_INPUT_CHANNELS;
Configuration.h:234: error: 'THERMOCOUPLE_0_PIN' was not declared in this scope
#define HEATED_BED_SENSOR_PIN THERMOCOUPLE_0_PIN
sketch/Repetier.h:473:37: note: in expansion of macro 'HEATED_BED_SENSOR_PIN'
#define BED_ANALOG_CHANNEL ACCOMMA5 HEATED_BED_SENSOR_PIN
sketch/Repetier.h:512:153: note: in expansion of macro 'BED_ANALOG_CHANNEL'
In file included from sketch/Extruder.cpp:22:0:
Repetier.h:485: error: 'FAN_THERMO_THERMISTOR_PIN' was not declared in this scope
#define THERMO_ANALOG_CHANNEL BED_KOMMA FAN_THERMO_THERMISTOR_PIN
sketch/Repetier.h:512:172: note: in expansion of macro 'THERMO_ANALOG_CHANNEL'
sketch/Extruder.cpp: In static member function 'static void Extruder::manageTemperatures()':
Extruder.cpp:86: error: 'FAN_THERMO_MAX_PWM' was not declared in this scope
pwm_pos[PWM_FAN_THERMO] = FAN_THERMO_MAX_PWM;
Extruder.cpp:89: error: 'FAN_THERMO_MIN_PWM' was not declared in this scope
float out = FAN_THERMO_MIN_PWM + (FAN_THERMO_MAX_PWM-FAN_THERMO_MIN_PWM) * (act->currentTemperatureC - Printer::thermoMinTemp) / (Printer::thermoMaxTemp - Printer::thermoMinTemp);
Extruder.cpp:89: error: 'FAN_THERMO_MAX_PWM' was not declared in this scope
sketch/Extruder.cpp: In static member function 'static void Extruder::setHeatedBedTemperature(float, bool)':
Extruder.cpp:871: error: expected primary-expression before ';' token
pwm_pos[PWM_BOARD_FAN] = BOARD_FAN_SPEED; // turn on the mainboard cooling fan
sketch/Extruder.cpp: At global scope:
Extruder.cpp:2695: error: 'FAN_THERMO_THERMISTOR_TYPE' was not declared in this scope
TemperatureController thermoController = {PWM_FAN_THERMO,FAN_THERMO_THERMISTOR_TYPE,THERMO_ANALOG_INDEX,0,0,0,0,0
exit status 1
