Endstop distance after homing problem.
My distance after homing for the X axis is set for 4mm but retracts 70mm while the Y and Z axis retract the proper 4mm.
The steps/mm are correct on all axis. The Y and Z axis retract the proper 4mm after homing. The exact same settings are used for the X and Y axis including microstepping.
Eeprom is disabled so it's not a stored Eeprom value.
This error occurs when using the printer display or by using Repetier-Host.
My only conclusion is there is a problem in the Repetier-Firmware. I plan on marketing this printer in the next month or so I need to have this issue resolved. It's the last big issue holding up the introduction.
Here are what I believe are the relevant settings:
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 63.94
#define YAXIS_STEPS_PER_MM 63.94
#define ZAXIS_STEPS_PER_MM 629.92
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define ENDSTOP_Z_MAX_INVERTING true
#define min_software_endstop_z true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 1
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 1
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 1
#define ENDSTOP_X_BACK_ON_HOME 4
#define ENDSTOP_Y_BACK_ON_HOME 4
#define ENDSTOP_Z_BACK_ON_HOME 4
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 1
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 275
#define Y_MAX_LENGTH 163
#define Z_MAX_LENGTH 217
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_PERMANENT 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 1
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
You use there a
and
#define max_software_endstop_x true (at 275mm / #define X_MAX_LENGTH 275)
Also have a look on Y the max is 163mm and distortion max upto 190mm
I did figure it out. Turns out it was the settings for the extruders. I setup 3 extruders with ext0 having 0 offset, ext1 having 34mm offset, and ext2 having 68mm offset. Yup. Where I thought the offsets would be taken from ext0, they were taken from ext2 instead. To me this is entirely counterintuitive given that it would be easier to design and set offsets from the first (ext0) extruder and not the last, later added extruders.
Nonetheless, reversing the offsets so that ext2 has 0 offset, ext1 has 34mm offset, and ext0 has 68mm offset fixed the problem.
Huh...
So, thank you again!
