First Printer Build
First Printer build hoping it wont be the last. hoping there is a guide to setting up Repetier for a Prusa I3 build.
Any help would be great really wanting to learn this software inside and out
Firstly - which pins on the Arduino 2650 does the XMin and XMax on a Ramps1.4 board connect with?
Next - my z level sensor (orange tipped) seems to have stopped working. The red led that used to light when it got close to the aluminium plate now does not light up.
Last: My delta has a 200mm x 3mm aluminium plate. I've got a 200mm heat bed. I have a beefy 12vdc lab power supply and control circuit/thermistor to run it. I'm not sure how to fit the heated bed physically. The tracks visible on one side of the heatbed are the same side that the 12v wires would be connected to. I'm assuming the track side goes topside to meet the aluminium plate. I could cover them with Kapton tape but that seems a really flakey idea to me. Also the wires are 2mm thick - so this would mean a 2mm gap between the heated bed and the aluminium plate on one side . That does not seem a sensible way to go.
So is there something I should put between the heated bed and the aluminium which would allow the wire spacing ?
