No temperature readings on smart LCD screen on Def
Hello, I am new here and new with repetier host, I am using the latest version of repetier firmware on ramps 1.4 and graphical lcd. But there is a problem with heating the bed and the extruder, on my lcd screen it shows extruder 1 OFF I can't tur nit on. On lcd there is Def instead of temperature for bed and for the extruder. Please look the picture below. If anyone have a solution for this please post it!
With best regards
With best regards
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 142.7
#define YAXIS_STEPS_PER_MM 142.7
#define ZAXIS_STEPS_PER_MM 5134
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_HEATER_PIN 0
#define EXT0_INVERSE 0
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_P 7
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN 196
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
What am I doing wrong?
Regards
