Delta Homing issues
Hello,
This is my first printer build and while i'm making good progress I've been stumped by a couple things. Hopefully I can get some hints. My printer is based off the boots biv1 rostock from thingverse. It's running sainsmart mega/ramps1.4 hardware with repetier firmware. I am using repetier host as well. My initial configuration was completed through the online tool.My google foo is weak when it comes to this so I really appreciate the help.
2) When I sent the machine the command to move the effector 30mm above the bed it crashed hard. I just found that my Z_MAX_LENGTH was incorrect which I just changed, haven't tested that yet though. Should the X, Y, and Z max lengths equal?
3) In the host when i home the X, Y, and Z coordinates in the manual control tab stay red and do not turn black after homing. According to the documentation I've read they should. Now I just re-measured the Z lenght and found it was way out like i mentioned in item 2. Other than that i'm not really sure where to start.
Thank you again!!
