Eeprom.cpp error
Hey guys just checking, but when I compile the repetier firmware from the configurator 0.92 on arduino 1.6.7. I get this error..
Eeprom.cpp:68: error: 'computeChecksum' was not declared in this scope
I have the eeprom disabled in the configurator because I want to calibrate without using the eeprom settings in the host then enable it later. Is this possible? Or do I have to have eeprom enabled?
So until the problem is corrected by Repetier I will use the EEPROM.
I know my english isn't the best but I hope this helps a bit.
