SD-Card Error
I have from time to time an SD-Card read error.  When this happens the printer stops and stay at the same place with temperature on. That is a problem, if I print overnight. Can I change the code, that the printer goes to a certain position and motors and hotend stop?
Has someone an idea? Thanks for any input!
  • A good idea. If we stop we should at least disable all heaters. You can add this in gcode.cpp where the stop is initated. Will see that I add it for the next 0.92 update.
  • Thanks for adding it!
    I found "SD read error" only in this part of the code of  in gcode.cpp.
    So what to add?!:
          if(n == -1)
                Com::printFLN(Com::tSDReadError);
                UI_ERROR("SD Read Error");
               // Kill hotend and bed temperature
                GCode::executeFString(PSTR("M104 S0/nM140 S0"));
                // Second try in case of recoverable errors
                sd.file.seekSet(sd.sdpos);
                n = sd.file.read();
                if(n == -1)
                    Com::printErrorFLN(PSTR("SD error did not recover!"));
                    sd.sdmode = 0;
                    break;
                UI_ERROR("SD error fixed");
    Is that correct?
    Sorry for my poor programming capabilities!
  • Yes, thats what I would try.
    So what to add?!:
          if(n == -1)
                n = sd.file.read();
                if(n == -1)
                    sd.sdmode = 0;
                    break;
    Is that correct?
    Hi Georg and Repetier :)
    My Kossel did the same thing last evening. I was very shocked when I saw the SD error message on the LCD this morning with the heating elements still switched on the whole night o_O
    I would change something at the suggested code:
          if(n == -1)
                n = sd.file.read();
                if(n == -1)
                    sd.sdmode = 0;
                    // Kill hotend, bed temperature and re-home
                    GCode::executeFString(PSTR("M104 S0\nM140 S0\nG28"));
                    break;
    Your solution was set at the first error. As you can see the printer tries to read from the SD card a second time below. If this try would succeed the printer would continue printing with switched off heating elements.
    Also I added a G28 to get the nozzle away from the print.
    Any ideas what could be done different or additionally?
  • I just realized that not all printer models home at the very top like a delta printer.
    The re-homing could be dangerous for a printer that homes the z-axis on the printbed. So here is a new version (from my own 0.92.8 version):
    if(n == -1)
                n = sd.file.read();
                if(n == -1)
                    sd.sdmode = 0;
                    Printer::kill(false);
    #if DRIVE_SYSTEM == DELTA
                    Printer::homeAxis(true, true, true);
    #else
                    Printer::homeAxis(true, true, false);
    #endif
                    break;
