Timelapse Video
Howdy,
I installed Repetier Server (still in freeware as I want to make sure I can use it for our need. We're planning to have it manager 2 - 3 printers with webcams. Right now I'm trialing with one. The goal is to run it off a R-Pi B+ and so far it's working great. We even managed to get a webcam working (external logitech). We also wanted to do timelapse for whomever's print is running. I went through the painstaking problem of building and installing FFMPEG of the pi (took about 6 hours) only to get a new error message.
" You have no static image source defined. Therefore no timelapse recording will occur. "
If I click on setup my values for stream and static are as follow respectively...
Both URL have been tested and work without an issue yet repetier seems to only accept the streaming one. Any idea on how to get past that?
