My extruder won't heat up
Ive tried everything. Every software version of repetier and still nothing . Its not my wire connector and I have voltage. I can manually set the temp on the extruder will printing. Also its not in dry run. Does anyone have any ideas for me to check? Also my g code says its telling to heat but nothing. Ive seen other people had this problem and fixed it but didn't come back and tell how they did that.
Here is my g code
Here is my g code
I'm having the same issue. It does look like when the nozzle reaches its temperature, the bed stops heating on mine. How do I fix that?
So check your gcode and analyse the log to see what goes on when it happens. It is either a command send or an error occuring and that is normally logged, also it depends on firmware you use.
As soon as i connect to Ramps Board and open Repetier Host
It shows extruder as 299.4 'c
I haven't heated the extruder
In log its showing as
Disabled all heaters due to detected sensor defect...
I seem to have a broken exteruder Heater.
But, the Repetier just keeps the Bed (to 65C), but skips Heating the Extruder - and just starts printing.
It does display 'Heating Extruder' on the top banner - but does not wait for the temperature to reach needed or any higher level.
The Extruder stays cold - and both displays 32C on the Printer and on the Repetier App.
And No , DryRun' is NOT enabled, I can see the Filament Motor actively grinding away at my non-moving Filiment - because the Extruder is still cold.
I tried shutting down the Printer & Repetier App multiple times
- it still skips heating the Extruder, before printing, after heating the Bed.
'Settings' - seem to have a 'Check Extruder Temp' option, but no Block if extruder not heating option.
*** Does Repetier intend on adding this 'Block Print if Extender Not Heating' Option / function ... ???
