compile error with 0.92.8
Little help please:
Arduino: 1.6.7 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\HAL.h:33:0,
from sketch\Repetier.h:480,
from sketch\gcode.cpp:24:
sketch\gcode.cpp: In static member function 'static void GCode::reportFatalError()':
ui.h:1993: error: initializer fails to determine size of '__c'
#define UI_ERROR_UPD(status) {uid.setStatusP(PSTR(status),true);uid.refreshPage();}
sketch\gcode.cpp:1044:2: note: in expansion of macro 'UI_ERROR_UPD'
UI_ERROR_UPD(fatalErrorMsg)
ui.h:1993: error: array must be initialized with a brace-enclosed initializer
exit status 1
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Not sure what is wrong, please help
I have the same configuration and the same error
configuration generated version 0.92.6 - compiles without errors
T
Thank you for your quick response and help
