Dimensional Inaccuracies
Hi, i have recently completed my delta printer and successfully setup repetier firmware and got it so the head moves flat over the bed, however, the size accuracy of the parts varies depending where it is printed on the bed, for example, printing something small in the center will be within 0.05mm of the correct size but printing larger or towards the edges of the bed the parts can be millimeters out, which setting do i have to change to correct this?
Thank you for your time
