Cross post from discussion - Z Probe and first layer problems
http://forum.repetier.com/discussion/1416/first-printer-layer-z-probe-offset-no-idea-what-to-do
Hey guys,
I have a friend that has been giving me a hand with setting up auto bed leveling and Repetier firmware.
The auto bed leveling works fine. My first layer consistently starts about
2mm above the bed (So, I'm printing in the air). We've changed several
settings and we end up getting the same results over and over.
Personally, I'm fed up with the entire process. I left Marlin behind to
be done with this exact issue and here we are again! lol
I'll paste my firmware here and hopefully someone can make some sense of it
and hopefully give me a hand. I'd greatly appreciate it, in fact!
I put it in pastebin (I think I did it right) please help!!!
Printer:
Mendel 90, 12V, HBP, Azteeg x3 pro board, Kraken hot end with only 2
nozzles setup, water cooled, using an induction sensor instead of a
servo and switch for the auto bed leveling routine.
http://pastebin.com/DH8iDj0A
Hey guys,
Printer:
Maybe:
#define Z_PROBE_Z_OFFSET 0
So, "#define Z_PROBE_Z_OFFSET -2.0" ??
#define Z_PROBE_HEIGHT 22
To
#define Z_PROBE_HEIGHT 18
With no change in first layer print height. Then I did this:
and again there was no change in the first layer print height. Absolutely no physical change has taken place and no other changes were made to the firmware other than this.
