Communication timeout - reset buffer block
Dear support,
I’m experiencing a persistent “communication timeout – reset buffer block” error while printing.
Here are the connection settings I’m using:
Port: COM (manually selected, not Auto)
BaudRate: 250000
Transfer Protocol: Autodetect
Receive Cache Size: 127
Communication Timeout: 40s
Firmware: Marlin
I’ve run multiple tests and the disconnection happens frequently. I’ve already replaced the USB cable, which improved things temporarily, but the issue returned—suggesting the root cause might be elsewhere.
This printer model has worked before with exactly these same parameters. I’ve also tried switching USB ports on the computer, but the timeout still occurs.
When the communication error happens, the Connect button remains blue, but the interface seems to freeze.
Appreciate any guidance you can provide on resolving this.
In any case, the ping-pong mode is disabled.
Camila
