Just got repetier on the davinci 2.0 duo, when i send the gcode to the printer it will run but not extrude. There are E0 codes in the gcode, am i missing something else?
Make sure dry run is disabled. Make sure extruder is hot. Check if steps per mm in eeprom is set correct. Check if extrusion mode is matching slicers output, relative or absolute. Normally slicer will make it correct if you do not override it. That are the normal reasons to not extrude.
I am encountering the same issue - just loaded Repetier onto a da vinci duo and no filament is coming out of the extruder. Can manually get filament when using the load function from the menu, but not when trying to actually print. What did you do to resolve your issue?
Make sure you send the M code for absolute/relative extrusion according to slicer settings. Especially if slicer is in relative mode and you have activated absolute extrusion there will be nearly no extrusion.
As a test if extrusion is working at all heat up to temperature and send G92 E0 G1 E10 F600
That extrudes 10mm equivalent of filament regradless of mode. Then you know motor is working as well and it is mode problem.
Can not say much about that fork, but check eeprom settings. If e.g. acceleration, max speed or steps per mm is 0 or NaN it won't move in our firmware, so there it would also be the case. Depending on changes eeprom might be wrong after reflash so you need to reset it to default values.
Can manually extrude but not when i send a print to the printer
Any help and advice would be greatly appreciated.
Dry Run - Disabled
Heaters always preheated
Bed heated
G92 E0
G1 E10 F600
flashed 0.92 https://github.com/luc-github/Repetier-Firmware-4-Davinci
can manually get it to spit out filament, but not when it should be printing
im ad 230c for extruder and 90c for bed
it worked before i flashed.
