Just got repetier on the davinci 2.0 duo, when i send the gcode to the printer it will run but not extrude. There are E0 codes in the gcode, am i missing something else?
Make sure dry run is disabled. Make sure extruder is hot. Check if steps per mm in eeprom is set correct. Check if extrusion mode is matching slicers output, relative or absolute. Normally slicer will make it correct if you do not override it. That are the normal reasons to not extrude.
I am encountering the same issue - just loaded Repetier onto a da vinci duo and no filament is coming out of the extruder. Can manually get filament when using the load function from the menu, but not when trying to actually print. What did you do to resolve your issue?
